B-8074
Why won't this fit?????
B-8074
I found a long frame plow (model# 76-42BC01) to use on my 1969 Charger 12 (model# 1-7241) and when I mounted it to the tractor and used the lift arm the bracket on the plow frame for the blades angle control arm hits the foot rest monting bar. I thought all long frame plows were interchangeable? This is a pic of the plow.
C-Series14
Your axle mounting bracket is mounted too far back. Yours is different than mine but I believe your angle pieces should be on the front of the axle OR below the axle (like mine does) which would move the blade forward some. Others will chime in if I am wrong....
B-8074
I feel stupid now!! :thumbs: I tried every thing but put the brackets in front of the axle. Oh well live and learn :D
C-Series14
Give it a try, it might make the difference. Mine is a little different, it mounts to the bottom.
B-8074
Well it worked. Thank you very much.
wheel horse man
heres the right bracket your suppost to have
