B-8074 19 #1 Posted July 19, 2010 This is my first hydro, and wanted to know if i could add a hydro deck lift since the tractor (69 Charger 12) didn't come with one? Also could this tractor run a loader? I've seen plans to build one to fit almost any size tractor. Share this post Link to post Share on other sites
jdog_kustoms 82 #2 Posted July 19, 2010 you can add hydrolic lift but you need a kit that goes in your rear to redirect the fluid you can also put a loader on it but will have to put a hydrolic pump on it that is ran buy the pto Share this post Link to post Share on other sites
B-8074 19 #3 Posted August 8, 2010 Does anyone know where I could get info on putting the lift option on my 69 charger? And could I use after market cylinders and valves? Maybe a few pics how it is all hooked up. I would like to use it to raise and lower the dozer/plow blade, and put a little down pressure on it. Also would like to be able to raise and lower rear attachment as well. Thanks. Share this post Link to post Share on other sites
refracman 166 #4 Posted August 8, 2010 To convert yours to hyd. lift you will need a cone & spring for your trans valve body but also the lift rock shaft besides the obvious. I have a complete kit for sale. It includes everything you'll need. if interested send me a email. Share this post Link to post Share on other sites
