bdunegan 0 #1 Posted July 12, 2010 took the hydraulic lift valve assembly off, thought i blew a hose, turns out it is an o-ring where the outside halves seal together. one side has the long oval o-ring, and the other side has two small ones(one each end) and a larger one in the middle. i blowed the larger one. problem is, toro parts viewer dont show a breakdown on the assembly, and no stores i have tried has one that matches the size. everywhere has the thick ones, and mine is a thin one. i have tried mower repair shops, tractor supply shops, and a hydraulic repair shop. anyone have any ideas where i can get one? i need to get it back together before i list it for sale or trade. Share this post Link to post Share on other sites
WH854 45 #2 Posted July 12, 2010 Put this Model# in 01-16KE02 Here https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Hope this helps Chas Look under hydraulic system :thumbs: Share this post Link to post Share on other sites
bdunegan 0 #3 Posted July 12, 2010 thanks for the info, but that is the same i get when i type my model number in(01-16KS01). what i need is the breakdown for part number 7(hydraulic valve) in the drawing. this comes apart in three pieces. right side, center, and left side. one side has a long oval rubber ring, and the other side has two small ones and a larger one in the center. so far all i have found have been correct diameter, but thicker. this wont let the two smaller ones seal off. the center one is thin, almost flat. Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #4 Posted July 12, 2010 Maybe this one? LINK I can't help you much with the breakdown pictures though. Share this post Link to post Share on other sites
