Kelly 1,037 #1 Posted July 8, 2010 Yes I said wheel gasket, I need a pair of the gaskets that go in the lawn ranger 2 piece wheels for the front, I can make them but I really don't have much to go by from the ones I have out of the wheels I just blasted, anyone just silicone them?? I know I have to leave a gap the grease fitting so grease will get to the bushings. Share this post Link to post Share on other sites
Don1977 605 #2 Posted July 8, 2010 Silicone will rust the metal, I wouldn't use it. How about a good rubber base windshield sealer. The other choice is tubes. Share this post Link to post Share on other sites
Kelly 1,037 #3 Posted July 9, 2010 With these rims you have to tube them, no way around that, the gasket is to keep the grease you pump into the rim from going up around the tube, and directs the grease to the wheel bearing/bushing And I've never had a issue with silicone and rusting parts, and windshield urethane will glue them together, I don't need that. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted July 9, 2010 No gasket listed in my book for 1963 to 1968 models. Could you use an o-ring? :thumbs: Share this post Link to post Share on other sites
oldandred 16 #5 Posted July 9, 2010 Kelly I never seen any eithor and i have all the rangers + a few extras Share this post Link to post Share on other sites
sorekiwi 761 #6 Posted July 9, 2010 When I first did my Ranger I just made them out of gasket paper. One of the origonals survived enough to use as a pattern. I probably still have it somewhere if you want a picture or dimensios. When I went to the tri-ribs I threw the gaskets away and just bolted the wheels together dry, and went with sealed bearings. As long as I remember not to grease them, I shouldnt have a mess! Share this post Link to post Share on other sites
buckeye 5 #7 Posted July 9, 2010 i used silicone on mine and it worked just fine. Share this post Link to post Share on other sites
Lawn Ranger kid 14 #8 Posted July 9, 2010 Mine have the gasket to. But it dosen't show it in the manual. I made mine out of a very thin cardboard. Josh Share this post Link to post Share on other sites
pfrederi 19,881 #9 Posted July 9, 2010 I made mine out of gasket material. Once you split the rim it is easy to trace the ID and the bolt holes. Just add about 3/4 inch to the ID for the OD...it isn't critical. If your wife is into scrap booking or other crafts she may have a cutter that makes circles. My wife has one and i use it as much as she does to cut perfect circles in gasket material. The cost 15 bucks or so and can be found at any craft store (AC Moore, Michaels etc) Share this post Link to post Share on other sites
