dustycarter 3 #1 Posted July 6, 2010 Hello. I have a 312-8 Kohler m12 I just rebuilt. Put it together and it was fine.started real good. But the thing is, I can only mount 2 holes to the frame and engine. Is there a bracket that goes there? It has been 2 years since I have taken it off and have forgot just about everything. If you have any pictures of your tractors with the mounts or how its supposed to mount, if you don't care please post them. I am just out of luck. Thanks Share this post Link to post Share on other sites
MikesRJ 563 #2 Posted July 6, 2010 look on the bottom side of the engine in the pan. there should be two tapped holes for two more bolts. See this post image: http://www.wheelhorseforum.com/index.php?...ndpost&p=160583 Share this post Link to post Share on other sites
jimt1971 239 #3 Posted July 6, 2010 Dusty, There are two threaded holes towards the center of the oil pan. Jim Share this post Link to post Share on other sites
rmaynard 17,642 #4 Posted July 6, 2010 In those two years since you took it off, you must have lost the factory issued "C" clamp Just kidding. The above posts are correct. Two bolts go up through the frame and into tapped holes in the bottom of the pan. Bob Share this post Link to post Share on other sites
Roger from southern Iowa 1 #5 Posted July 6, 2010 Bob, you amaze me!!! :D Share this post Link to post Share on other sites
rickv1957 77 #6 Posted July 7, 2010 In those two years since you took it off, you must have lost the factory issued "C" clamp Just kidding. The above posts are correct. Two bolts go up through the frame and into tapped holes in the bottom of the pan. Bob Bob, Rick Share this post Link to post Share on other sites
dustycarter 3 #7 Posted July 7, 2010 Thank you Mike and Jim. I got it mounted just right. i really do appreciate it. Thanks again. As far as Bob goes I probably would have believed it. Thank goodness those guys chimed in first. Haha just joking. I knew it was mounted somewhee just couldn't figure out where. Share this post Link to post Share on other sites
dustycarter 3 #8 Posted July 7, 2010 look on the bottom side of the engine in the pan. there should be two tapped holes for two more bolts. See this post image: http://www.wheelhorseforum.com/index.php?...ndpost&p=160583 Thanks a bunch for the picture. It helped. I went out there and low and behold I seen them lined up perfectly. Thank you very much for the picture :thumbs: Share this post Link to post Share on other sites
frankiefiredog 1 #9 Posted July 7, 2010 I feel a LOT better now. It's good to know you're not alone. My new motor is now mounted in it's proper place with the proper bolts in the proper holes :thumbs: Share this post Link to post Share on other sites
dustycarter 3 #10 Posted July 7, 2010 I feel a LOT better now. It's good to know you're not alone. My new motor is now mounted in it's proper place with the proper bolts in the proper holes Same trouble huh? Oh well. Glad I'm not alone either. Thanks. Share this post Link to post Share on other sites
dobeleo 7 #11 Posted July 7, 2010 I had the same question on my tractor. I just ended up painting my C-Clamps Red. Share this post Link to post Share on other sites
Duff 207 #12 Posted July 7, 2010 I had the same question on my tractor. I just ended up painting my C-Clamps Red. Duff :thumbs: Share this post Link to post Share on other sites
rickv1957 77 #13 Posted July 7, 2010 I had the same question on my tractor. I just ended up painting my C-Clamps Red. Duff Nice to have a little fun!! Rick Share this post Link to post Share on other sites
