876wheelhorse 46 #1 Posted July 5, 2010 it is a 856 getting frustrated it keeps throwing the belt off the idle pulley. i will get it back where it needs to be put the gaurd back on and start it up throws it off........so mad it is now being punished like the 876 was sitting outside and possibly going bye bye....... :thumbs: Share this post Link to post Share on other sites
rickv1957 77 #2 Posted July 5, 2010 Does your idler have the L shaped belt keeper that keeps belt on pulley when you push in clutch,Im guessing not,Rick Share this post Link to post Share on other sites
Kelly 1,038 #3 Posted July 5, 2010 What Rick said, and check the bearings in the idler pulley Share this post Link to post Share on other sites
876wheelhorse 46 #4 Posted July 6, 2010 everything is free 7the L shape bracket is there. I went out tonight after it cooled down some tore it apart and put back together. Well it went well and it stayed on. i made room in the shed and it is even under roof now. would this be a worn belt maybe causing this???? Share this post Link to post Share on other sites
tgranthamfd 29 #5 Posted July 6, 2010 If your L shaped bracket is bent to far away from the belt and pulley, it will jump too. It needs to be close enough that the belt can't just squeeze out. Share this post Link to post Share on other sites
