Lane Ranger 11,741 #1 Posted June 10, 2010 I just received some new spindle bearings for my backup B-80 36 inch mower deck. I replaced two on the deck I am now using but that was two years ago. TURF TRACTOR SPINDLE BEARINGS 230-078 for TORO 103119 is what I have. I have fogotten which way the long side of the bearing goes - up for the pulley on top on down for the spindle cup and mower blade? I think the bearing is about an 1/8 to 1/4 inch longer on one end. These are stens bearings and have a ring/grove on one of the Double D ends of the bearing. I sure would appreacaite some guidance on which way is up on these! I probably am too tired to finish two of them tonight anywaY! Thank you Red Square members! :D Share this post Link to post Share on other sites
Lane Ranger 11,741 #2 Posted June 11, 2010 Anyone know which way to install the spindle bearings for the 36 inch mower wih the sealed bearings?? TURF TRACTOR SPINDLE BEARINGS 230-078 for TORO 103119 is what I have. I have fogotten which way the long side of the bearing goes - up for the pulley on top on down for the spindle cup and mower blade? I think the bearing is about an 1/8 to 1/4 inch longer on one end. These are stens bearings and have a ring/grove on one of the Double D ends of the bearing. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #3 Posted June 11, 2010 The short end goes up, Lane. When the spindle unit is assembled, the shaft ends protrude almost equally - due to the lip at the bottom of the housing. (where the bearing unit seats) 1 Share this post Link to post Share on other sites
