Electro12WH
Shifter Setscrew
Electro12WH
The set screw on my trans doesn't have the point I'm familiar with. It has a straight unthreaded portion on the tip that goes into a straight hole on the shifter ball. How deep should I insert this pin? All the way?
rickv1957
You can screw it in untill shifter gets tight then back of a little allowing free movement,Rick
Electro12WH
Okay, thanks!
