wfopete 69 #1 Posted April 16, 2010 On the first cutting of the year my C-111 died on me yesterday while mowing. It acted like it was running out of fuel, even though it had a full tank and was getting fuel to the carb. The B&S carb looked pretty grungy so I removed it to check it out. Surprisingly the carb was remarkably clean but when I went to put it all together I didn't see a rod to activate the choke linkage. So I'm thinking: Dang should have taken some digital pics before I pulled this apart but then I thought maybe this is why it quit running (the linkage for the choke fell off and the thing went to full choke and couldn't breath) Can someone supply a picture or drawing of the throttle/choke/govenor set up so I can compare it to what I have? I may have just not figured out the correct assembly of the linkage but I can't see how it could work a choke with what I have now. Share this post Link to post Share on other sites
rick 321 #2 Posted April 16, 2010 The choke on my C-111 is controlled by the choke cable, which attaches to the choke actuating lever. Sorry I don't have pictures, I spent all my money buying and fixing up my Wheel Horse tractors. I don't even have a camera on my cellophone. Share this post Link to post Share on other sites
wfopete 69 #3 Posted April 16, 2010 Ok, that's important, I mean how the choke is controlled. Mine only uses a single cable to work both the choke and the throttle, if that helps. Share this post Link to post Share on other sites
