v65animal 0 #1 Posted April 6, 2010 I've been told to stay away from the Onan engines. How bad are they? Previously I had always heard good things about them since they were used in Generators. Is it just that now the parts are harder to find and more expensive? Or is there something just wrong with the ones used on the Wheel Horses? Are they generally reliable to start and run smoothly? I need a sturdy machine, and the 520's have the cool factor to go with it, but I don't want to get into spending more on repairs than I did on the tractor to begin with. I'm looking to spend under $1500, 42 or 48 inch deck, 300, 400, or 500 series. Thanks, Sam Share this post Link to post Share on other sites
Wheel Horse Fan 3 #2 Posted April 6, 2010 The Onans are fine engines. I believe there were some issues with one or two years of the 20 hp models (someone please correct me if I'm wrong). If they are maintained they will last just as long as any other small engine. There are a few guys in this forum that have over 2000 hours on theirs. Parts are more expensive then a single Kohler, but you can't beat the sound and the power. I wouldn't be afraid to buy one as long as it appears that it was maintained by someone with half a brain. Good luck with your search. Share this post Link to post Share on other sites
Operator 7 #3 Posted April 6, 2010 As you can see in my signature I'm not scared of them! Keep them clean, I use an air hose after mowing, change oil at least every 50 hours, keep air filter clean. I've gone to Terra Haute for one! Randy Share this post Link to post Share on other sites
rickv1957 77 #4 Posted April 6, 2010 The Onans are very good long life engines,Rick Share this post Link to post Share on other sites
barns1 57 #5 Posted April 6, 2010 Good engines. But I remember the owners manual stating to follow the recommended maintenance schedule closely, especially de-carbonizing the heads. Share this post Link to post Share on other sites
Confused99 2 #6 Posted April 6, 2010 I love my Onan and when the time comes, I am willing to drop the $$$ into rebuilding it but, I have 1400 hours and counting. Jason Share this post Link to post Share on other sites
jtmoyer 1 #7 Posted April 6, 2010 i have or have had an onan 16,18,and 20 horse. all have run smooth and sounded great. you just have to make sure you don't get the 20 horse hot. animal do you have a v65? Share this post Link to post Share on other sites
jpmcleod 4 #8 Posted April 6, 2010 Nothing sounds better than an Onan. I have a 20 and when I crank it up, it just has that sound you love. Other than carbutator problems, no problem with the motor. When I got mine, I had to pull the heads off and un-stick the valves. Put it back to gether, runs great. I wish I had more than one. Share this post Link to post Share on other sites
GlenPettit 1,719 #9 Posted April 6, 2010 The first 20 hp Onan engines Wheel Horse used had a problem with the "oil splasher" for lubrication; when that tractor was tilted while plowing soil or tilted driving on the side of a ditch/hill for a length of time, that splasher didn't properly lubricate the engine and the engine overheated. But, it was corrected/fixed by Onan when they realized the problem, but for some Wheel Horses it was too late. After that first batch of problems, the engines were very good. Also heard that it only happened when the left side was high, and for flat lawn mowing that same early engine worked just fine. Share this post Link to post Share on other sites
chdinct 28 #10 Posted April 6, 2010 I have 625 hours on mine and so far, it's been the best gasoline engine I've owned. Starts right up every time, better than a Kawi liquid cooled I owned for a short time. Gobs of power, but high fuel usage to match. I do the regular maintenance though. I do hear parts are a bit higher vs Kohler. I've also read many posts that Onan parts are no longer available, but I believe that is not accurate. I've see posts by Onan parts dealers stating just about everything is still available. Only thing I've ever needed engine wise was a new fuel pump. Now, what is this head de-carboning requirement? Don't recall that in my manual, but I haven't looked at it in quite a while. Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #11 Posted April 6, 2010 The first 20 hp Onan engines Wheel Horse used had a problem with the "oil splasher" for lubrication I believe you're thinking of the KT Kohlers, Glen. Onans twins had full-pressure lubrication (and oil filters) long before Toro ever stuck one on a Wheel Horse. :omg: Share this post Link to post Share on other sites
refracman 167 #12 Posted April 6, 2010 To decarbonize the heads need pulled and scraped clean, also part of the 600hr maintainance is adjusting the valves. Funny thing about Onan valves they tighten up instead of loosening up like all they the others. Been told its a prime cause of the valve seats popin loose. You'll need intake, exhaust and head gaskets, cost is about 100 bucks depending on your source, besides oil and air filters. Definitly not cheap for parts. Share this post Link to post Share on other sites
chdinct 28 #13 Posted April 6, 2010 To decarbonize the heads need pulled and scraped clean, also part of the 600hr maintainance is adjusting the valves. Funny thing about Onan valves they tighten up instead of loosening up like all they the others. Been told its a prime cause of the valve seats popin loose. You'll need intake, exhaust and head gaskets, cost is about 100 bucks depending on your source, besides oil and air filters. Definitly not cheap for parts. Thanks refracman - having just past 600 hours, guess I should look into decarbonizing it. Share this post Link to post Share on other sites
v65animal 0 #14 Posted April 7, 2010 i have or have had an onan 16,18,and 20 horse. all have run smooth and sounded great. you just have to make sure you don't get the 20 horse hot. animal do you have a v65? Yes, I had a V65 Magna, 2 actually, but sold them. I had a Nighthawk 650 for about a month inbetween then had to go back to a V65 Share this post Link to post Share on other sites
