Butch 194 #1 Posted March 21, 2010 I guess the time has come to buy a welder. I have ever welded in my life nor have I ever seen anybody weld. Looking for a welder to work on the Wheel Horse, mower deck, car chassis, wagon, garden implements and such. Maybe welding some exhaust work on cars. What kind of welder should I buy with no experience to work on the mentioned items? I was looking to spend no more that $1200.00 which is surprising how low end that price is for welders. I was looking at the Miller 211, a mig welder, which works on 110 and 220 of which I have both in the garage. Any ideas or recommendations? Thanks. Butch S. Jersey Share this post Link to post Share on other sites
porkchop 1 #2 Posted March 21, 2010 I have had or used every kind of welder you can think of!!! Welding has always been part of my job description for 30 years. At home I have now downsized to a miller 140 that works off 110 volt. I can weld up to 3/8 thick with it and they are priced around $750. What ever you buy make sure it,s not some fancy digital controlled nightmare unit with alot of bells and whistles. A heat selector and wire feed control are all thats required. Keep it simple!!! Mig is the way to go for a garage shop and MILLER IS THE ONLY WAY TO GO. :omg: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #3 Posted March 21, 2010 I do a lot of welding, but am definitely not a "welder". I have to go with Randy on Miller being a good machine. I had a 120V / 135 amp wire feed unit for a few years until it got fried by an incorrectly-wired 120V receptacle (240V) and replaced it with one of the new 140 Auto-Set machines. It's perfect for 90% of what I work on but it can't handle anything thicker than 1/4" without making multiple passes. (I use .023" wire) I do have access to a larger 240V "mig" at work, so that's where I do the thicker stuff. :omg: Share this post Link to post Share on other sites
jimbotelho 1 #4 Posted March 21, 2010 I agree with the other 2 posts miller or lincoln would be my choice definitely a mig as their are so many other things that you can weld where as a stick welder isit has its limits just my 3 cants being an ex pipewelder Share this post Link to post Share on other sites
Butch 194 #5 Posted March 21, 2010 TT I could have done without your first sentence! Not what I like to hear! Hard to believe something that looks so simple can be so hard. I was gonna take a welding course at the local Vo-Tech last year but didn't. Maybe his Fall. I thought you just pulled the trigger and either pushed the handle forward or dragged it backward!! I guess I'll go with the Miller. I did like that autoset they had which would take any guessing out. Do you guys use it with or without gas? Butch Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted March 21, 2010 Do you guys use it with or without gas? I have always used the C-25 (75% argon/25% CO2) shielding gas. (steel welding) I don't think I have ever welded with flux-core wire and from what others tell me - I really don't want to. I think the welding course is a great idea and actually received "the basics" while attending vo-tech during high school. :omg: Share this post Link to post Share on other sites
porkchop 1 #7 Posted March 21, 2010 :omg: I agree with TT 75/25 gas. Share this post Link to post Share on other sites
Butch 194 #8 Posted March 21, 2010 I agree with TT 75/25 gas. Does that mean I need two bottles instead of one? Share this post Link to post Share on other sites
Indy w h 5 #9 Posted March 21, 2010 75/25 is the gas mixture Its just 1 tank Indy Share this post Link to post Share on other sites
rickv1957 74 #10 Posted March 21, 2010 No,it is a mix,Rick,like my miller 210! Share this post Link to post Share on other sites
Butch 194 #11 Posted March 21, 2010 Ah, good! It's a ratio mix with only 1 bottle! Still gotta buy a bottle, helmet and gloves too. $1500 to fix two cracks in my mowers deck sounds just about right to me!! Thanks!! Butch S. Jersey Share this post Link to post Share on other sites
Indy w h 5 #12 Posted March 21, 2010 If your wanting a small mig welder, Lincoln makes a nice 110v benchtop welder good up to 1/4 in. Indy Share this post Link to post Share on other sites
Gene_S 93 #13 Posted March 22, 2010 I use a Snap-On 140 amp 110V welder with .035 wire flux core. What is the diffrence between using flux core and gas? Is that why the weld berries stick everywhere on my work? I just love the auto darkining helmets Butch... But not a necessity, the original helmets work fine to. Share this post Link to post Share on other sites
DMK855 15 #14 Posted March 22, 2010 Butch, the Miller is a real good machine. Really like my Snap On Muscle Mig 250 though. Good luck with your deck!! A welder is almost a must have in playing with these old tractors!!! Haasman, the flux cored wire will work, but does not yeild the quality of weld you will get with a gas mig!! The gas is only a "shield" for the weld!! Splatter is more prevalent with flux cored wire, but can also be from other conditions. Share this post Link to post Share on other sites
6wheeler 669 #15 Posted March 22, 2010 I am gonna go with TT on this, I too weld alot but I am not a welder.. I have a miller wire feed also. Shielding gas is a must, flux core sucks. I also have an old Miller Thunderbolt 125 stick welder. The wirefeed is great for lighter stuff, But Remember, they do NOT weld outside well if there is a stiff breeze or windy. With my stick welder, I can weld any where (Except under water ) with this welder I can weld as light as 1/8 up to 5/8 material. But, the wire feed is much easier to use. The wind blows the shielding gas away and you get alot of splatter. I personally like to have both, but I have room for that. Just my .02 cents Pat Share this post Link to post Share on other sites
Butch 194 #16 Posted March 22, 2010 Wow! What's with you guys that weld a lot but aren't welders? I hope that doesn't mean your welding sucks. I hope to be able to do at least some decent work. I guess a welding class is starting to look like a must! I have my eye on the Miller 180 and the 211. I like the 211 because it operates on 220v and my outlet is along side where I work on our cars. How much splatter and wind will determine whether I weld in the garage or outside. Butch Share this post Link to post Share on other sites
dkopp 1 #17 Posted March 22, 2010 Does anyone have any experience with the Hobart brand of welders, such as the Handler 135 or 140? Share this post Link to post Share on other sites
Indy w h 5 #18 Posted March 22, 2010 Butch, if it's windy out side it'll blow the gas away from the weld. Causing the weld to get kinda "ugly". It's best to weld inside unless it's a calm day. You can buy an aerosol can of anti-stick and spray it on the parts you don't want the little weld balls or "boogers"to stick to Indy Share this post Link to post Share on other sites
DMK855 15 #19 Posted March 22, 2010 dkopp, I had a Hobart 140 and really liked it for the home garage. I upgraded to the Snap On for TIG capabilities!!! Share this post Link to post Share on other sites
bell 11 #20 Posted March 22, 2010 Does anyone have any experience with the Hobart brand of welders, such as the Handler 135 or 140? I have a Hobart Handler 140 and it is the best welder I've ever used. I was surprised that nobody had mentioned a Hobart yet. Afterall, they are made by Miller and the only difference between a Miller and a Hobart of comparable size is that the Miller is Infinitely adjustable, meaning that you have 4 power settings on a Hobart... 4 clicks, it's either on 1, 2, 3 or 4... A miller can be adjusted to anywhere in between those clicks with a smooth rotary dial, no clicks. To me, the Hobart is a FANTASTIC welder... And, you can pick one up with the cart and regulator for just over $500. I have run about 8 large spools (I believe 10lb) of wire through mine and it still works as good now as the day I brought it home. Now, on to the flux core wire... I have found that welding with flux core wire, you get better penetration than with solid wire and shielding gas. The only drawback is that there is a little more cleanup involved with flux core. I am not a expert by any means, but one of my recent projects used 3 spools (the large ones, not the 2lb ones) of wire, so I have a lot of experience with flux core and solid core. Hope this helps you, and good luck! Share this post Link to post Share on other sites
Butch 194 #21 Posted March 22, 2010 3 LARGE spools of wire on one project? I don't have a clue how far the spools of wire go but I thought 3 large spools would last me more than a lifetime. Can't wait to see how much the spools cost. Butch Share this post Link to post Share on other sites
bell 11 #22 Posted March 22, 2010 It was a 2003 Chevy Tracker, that I TOTALLY rebuilt into a off-road rig... It was lots of fun and I got a LOT of welding practice on it... If I remember correctly, the last spool of wire I bought was almost $70.... But, for occasional use, that should last you a LONG time. Share this post Link to post Share on other sites
Coadster32 793 #23 Posted March 22, 2010 :omg: That thing looks kick butt!! I was looking at a hobart140 myself. My buddy has one, and says it's really nice to use. Share this post Link to post Share on other sites
Butch 194 #24 Posted March 22, 2010 Sweet!!! And all that welding work was done with a Hobart 140 mig welder? Share this post Link to post Share on other sites
KC9KAS 4,744 #25 Posted March 22, 2010 Hobart, Miller, Lincoln are all good welders, and offer all kinds of bells & whistles if you want. Like most everything else, you can spend a little, or spend a lot! I had used stick welders for 10-15 years before I had the opportunity to use a MIG...Now, I go for the MIG all the time. I have had better luck with the gas rather than using the flux core. You will not regret taking a welding class at a VO-TECH....as long as the instructor(s) really does know what they are talking (teaching) about. Good luck in your venture of becoming a welder! Share this post Link to post Share on other sites
