1961551 2 #1 Posted March 16, 2010 hi, i have a good running k341 engine. the only tractors i have, that i know it will fit on is the c165 and the c81. i want to know if it will fit on a short frame or med frame without modifying the tractor i guess i could have already tried, but its heavy. and someone already knows . jimmy Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #2 Posted March 16, 2010 Big or little oil pan? Share this post Link to post Share on other sites
1961551 2 #3 Posted March 16, 2010 terry, i dont know. just went out and measured the oil pan. is 1-1/2 inches deep. its a k341AS. jimmy Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #4 Posted March 16, 2010 The "A" in "AS" means it has a "special oil pan" which - in Kohler and/or WH terminology means the smaller pan. (but not necessarily the correct pan for use with the iso-mount cradle on a WH tractor) With the proper pan and air cleaner, you can actually put the engine on a short-frame square-hood tractor such as a 1045/1055/1075, but it would have to have a starter/generator and not a gear drive starter. (unless you relocate the battery) The medium frame tractors (B-80 4 speed, B-100 Automatic, etc.) shouldn't be a problem - other than fastening the engine to the frame without the big oil pan. You can't use the iso-cradle because there isn't enough room on the frame. I don't see it working well on a round hood unless you severely alter the hood or remove it all together. Share this post Link to post Share on other sites
Kelly 1,038 #5 Posted March 16, 2010 Just to clear one thing up, that TT said the K341 small pan, will not fit the short frame tractors with out a little more work, I have one on my rat tractor and the flywheel is bigger, even with the ring gear removed, I used the tin work from a 1257 I believe, but the bearing plate is larger than the 10hp engines on the 1055 ect... so I had to shift the engine to the left (from the seat view) to clear the frame and that screwed everything up, but with work it did fit, I don't think you can or should swap the small 10hp flywheel to theK341. Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #6 Posted March 16, 2010 OOPS...... I guess I should have specified complete starter/generator set-up. That would include everything from the block outward. (bearing plate, flywheel, shroud, etc.) The Kohler flywheels are "zero balanced" and will interchange. (Didn't the CC 169 still have a small flywheel?) Share this post Link to post Share on other sites
Kelly 1,038 #7 Posted March 16, 2010 Ok I didn't know that wish I did, I'm not changing it back now, Thanks TT I guess we are both right, you more than me. And Yes I believe the CC 169 was a small flywheel with starter gen. I had a guy here looking for one last summer, my engine came off a CC 1650 Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #8 Posted March 16, 2010 Too many "if's", huh, Kelly? When in doubt, get the SAWZALL out! :omg: Share this post Link to post Share on other sites
Horse Rancher 0 #9 Posted March 16, 2010 the bearing plate and flywheel will interchange from 10hp k241 to the 18hp k361 I have done this several times with good sucess just remember to check crank bearings and reset end play on crank if it is a shallow pan you can use the cub cadet flat 10hp pan and a muont plate from raiders with a tecumseh and its a direct bolt in setup Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #10 Posted March 16, 2010 if it is a shallow pan you can use the cub cadet flat 10hp pan and a muont plate from raiders with a tecumseh and its a direct bolt in setup Not on short frame tractors with the "low" hoodstand. The oil pan HAS to bolt directly to the frame. Share this post Link to post Share on other sites
Horse Rancher 0 #11 Posted March 16, 2010 Sorry TT the oldest I've done this with is a B-60 Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #12 Posted March 16, 2010 the oldest I've done this with is a B-60 Awwwww, c'mon! B-60's aren't OLD! :D Share this post Link to post Share on other sites
