chris11 184 #1 Posted February 21, 2010 Is there a id tag? i picked up this tractor it looks like a 62 552. There is no belt guard, engine or hood. I dont see a tag on the frame. Thank you Share this post Link to post Share on other sites
rickv1957 77 #2 Posted February 21, 2010 My 702 has a stick on decal on lower dash tower with #,Rick Share this post Link to post Share on other sites
chris11 184 #3 Posted February 21, 2010 No tag on this one. Share this post Link to post Share on other sites
Kelly 1,038 #4 Posted February 22, 2010 Post apicture I'm sure we can get you very close on a model and a year get the front of the tractor both sides and the dash area. Share this post Link to post Share on other sites
sorekiwi 761 #6 Posted February 22, 2010 There is no ID tag as such, but there should be a serial # on the shift decal: The bad news is that this wont help much in identifying the model. As Kelly said, post some pictures and we should be able to work it out. Share this post Link to post Share on other sites
Sparky-(Admin) 25,944 #7 Posted February 23, 2010 Heres Chris's tractor. Mike........ Share this post Link to post Share on other sites
Kelly 1,038 #8 Posted February 23, 2010 It's a 1962 for sure, I'm guessing a 702 or 552 both being elect. start, and this has the starter button. Share this post Link to post Share on other sites
sorekiwi 761 #9 Posted February 23, 2010 You might be able to tell whether it was a 552 or 702 by the marks on the frame where the motor was bolted down. The Kohler had a cast iron oil pan bolted directly to the frame, whereas the Tecumseh was mounted on a riser plate. Or maybe there's enough of the wiring left to tell? Doesnt matter really, they were the same tractor with different motors. Share this post Link to post Share on other sites
BPjunk 184 #10 Posted February 23, 2010 From the picture posted the Wheel Horse in question appears to be a model 702. Look to see if there is a wire coming from the battery to the ignition switch. If so it is a 702 as a 552 will just a wire that will be a short to ground. Wild Bill Share this post Link to post Share on other sites
chris11 184 #11 Posted February 23, 2010 Thank you guys, Ill put this one on hold till the other one is done. thank you again Share this post Link to post Share on other sites
