dandan111 66 #1 Posted February 15, 2010 Have any of you guys heard of a kit to make the front snow blade lighter? I have been plowing with my 314-8 for years lifting this heavy blade. My kids are now getting older and I would love for them to be able to plow but their is no way they can lift this blade. Would a spring not let the blade have enough down pressure to plow correctly? Share this post Link to post Share on other sites
clintonnut 127 #2 Posted February 15, 2010 The lift assist was for the snowblower only. You can make the blade easier to lift by putting the rod in a hole closer to the pivot point on the lever. All about leverage . You could probably use a spring and hook it from the blade to the frame but it might not let the blade have enough down pressure. Just try experimenting. Charlie Share this post Link to post Share on other sites
Kelly 1,038 #3 Posted February 15, 2010 I'm not sure if you can make one work on a snow blade, they work on blowers and tillers. You just need to buy a hydro tractor with hyd. lift easier to drive and lift the plow. Share this post Link to post Share on other sites
rickv1957 77 #4 Posted February 16, 2010 A spring might help if you get yhe right one,trial and error,Rick Share this post Link to post Share on other sites
bitten 134 #5 Posted February 16, 2010 I dont know but maybe check to see that you have the lift rod in the right slot. Good Luck. Share this post Link to post Share on other sites
MikesRJ 562 #6 Posted February 16, 2010 The official Wheel Horse kit looked like this: http://www.mywheelhorse.com/graphics/file/...tKit_803954.pdf Fairly simple to make yourself if you can make the metal part, have it welded and can get the spring locally. Share this post Link to post Share on other sites
dandan111 66 #7 Posted February 16, 2010 Mike, It looks like the spring is at a angle, maybe being set up like that would keep the down pressure. Thank you for the link. Share this post Link to post Share on other sites
MikesRJ 562 #8 Posted February 16, 2010 It's not for down-force, hence why they call it a lift assist. When you pull the Lift Handle toward you the Lift Arm connected to the blower moves forward to raise the blower. The spring reduces the pull-back force at the Lift Handle by approximately 50%. Share this post Link to post Share on other sites
tgranthamfd 29 #9 Posted February 16, 2010 I don't know but maybe check to see that you have the lift rod in the right slot. Good Luck. Anybody have a picture of the correct slot??? Mine is kinda heavy, too. Share this post Link to post Share on other sites
whfan74 2,073 #10 Posted February 16, 2010 Always could rig up a winch that is connected to a plate that mounts on the frount attach a matic. If memory serves me right they had something like that on ebay..... Try this out............. http://cgi.ebay.com/wheel-horse-wheelhorse...=item4a9e9aba80 Share this post Link to post Share on other sites
wheel horse 1045 2 #11 Posted February 16, 2010 i know a guy who has 1 and it was neat but slow Share this post Link to post Share on other sites
WheelHorse_of_course 101 #12 Posted February 17, 2010 Welllll Slightly off topic , but still relevant I think... Is there any sort of lift assist for implements that do not use the lift rod and flag? Specifically I have found that Brinly accessories attached to the slot hitch ( see adaptor here: http://www.wheelhorseforum.com/index.php?...hl=sleeve+hitch ) are really hard to lift. Is there some other lift assist for rear-hitch accessories? :clap: Share this post Link to post Share on other sites
BPC23 18 #13 Posted March 18, 2010 Just for the record, here's the lift assist used with a snowthrower. http://www.wheelhorseforum.com/index.php?...topic=13977&hl= Brian Share this post Link to post Share on other sites
