jdwheelhorse 0 #1 Posted February 6, 2010 I was just plowing snow and i noticed that my B80 4speed was hard to get into first and neutral, so i stopped for a minute and shifted it through the gears and when i went to take off again, nothing. My shift lever will come completely out of the tranny and if you put it back in, it grinds...so whats my problem and is it terminal or can it be fixed? and How? THanks Share this post Link to post Share on other sites
pfrederi 19,807 #2 Posted February 6, 2010 Remove the shifter and boot. Look inside to see if the shifter forks are aligned. If not use a big screw driver to align them...that will be neutral. Back out the dog point set screw on the raised part of the housing (faces forward). Note the hole in the shifter ring. The dog point will go into that. Put the shifter back in getting the ball end between the forks. Screw in the set screw (into the hole on the shifter ring) until it is tight. Back it of about a half turn. Shifter should move freely but not pull out. Secure the lock nut on the dog point set screw and try her out Share this post Link to post Share on other sites
rickv1957 77 #3 Posted February 6, 2010 Well said Paul!!, Rick Share this post Link to post Share on other sites
jdwheelhorse 0 #4 Posted February 6, 2010 great descriptive post! thanks..i had to read it twice lol. Ill go try that here in a min. Share this post Link to post Share on other sites
Dw Andy 0 #5 Posted February 6, 2010 Why did the shift come out, Is the screw loose or worn? A while back I was shopping for a tractor to mow with , and I seen this JD that I liked. I told Muriel that I would hafta paint it RED cause I can't have a green tractor on the place B) Share this post Link to post Share on other sites
CasualObserver 3,411 #6 Posted February 6, 2010 Why did the shift come out, Is the screw loose or worn? Probably because the jam nut wasn't snugged up tight enough. it's a common problem and an easy fix! Hope you're back up an running already! Share this post Link to post Share on other sites
Duff 206 #7 Posted February 6, 2010 I think I read here somewhere in the past that the dog point set screw can (although rarely) wear out or break off. Replacing it is both cheap and easy. I've got to go to work or I'd try to locate the thread for you that discusses it - it's somewhere around here....... Duff :party: Share this post Link to post Share on other sites
can whlvr 994 #8 Posted February 7, 2010 ive had to drill and tap some when the dog screw stripped the threaded hole Share this post Link to post Share on other sites
jdwheelhorse 0 #9 Posted February 7, 2010 I think the head is broke off the screw so should i just try to get it out and then find something similiar? And can someone tell me what head comes on the original set screw? Share this post Link to post Share on other sites
pfrederi 19,807 #10 Posted February 7, 2010 There is no head on the set screw it uses an allen wrench in the end of the set screw and a jam nut to lock it in place. Share this post Link to post Share on other sites
MikesRJ 558 #11 Posted February 7, 2010 The correct part is a dog-point set screw similar to the image shown below. It's only about 3/4" - 1" long and 1/4-20 I believe (don't quote me on that). There is a single jam nut which holds the set screw in place, once the proper pressure is applied between set screw and shifter ball. Share this post Link to post Share on other sites
Duff 206 #12 Posted February 7, 2010 There is no head on the set screw it uses an allen wrench in the end of the set screw and a jam nut to lock it in place. Paul's right - the dog screw has no head and thus you may think it's broken off. Don's second picture above shows a possible fix using a regular 1/4" (I think) bolt that the end that goes inside the tranny has been filed or ground to resemble Mike's drawing. Duff B) Share this post Link to post Share on other sites
rickv1957 77 #13 Posted February 7, 2010 I have extra new shifter screws if you need one,just pm me,Rick Share this post Link to post Share on other sites
Iggy68 28 #14 Posted February 7, 2010 I had the same problem with mine. Two owners ago he tried to fix it. To say the least he did a poor job. I had to drill out the hole and thread it to a 5/16 set screw. I drilled the end of the new set screw and put a rool pin in it. This might woork for your situation too. Just another idea, good luck! Share this post Link to post Share on other sites
Buzz 502 #15 Posted February 8, 2010 I had the problem today where it got stuck between gears. The set screw had backed out a little so I took it out further and pulled the shifter. Took a long thick screw driver to line up the shifting forks and reinstalled the shifter. Snugged up the set screw ,and when I went to back it out a little the end and jam nut broke off It shifted okay the way it is so I finished the driveway, shifting gently, then put it in the shop. Tomorrow I'll see if I can find one and change it, they're calling for more snow on Tuesday It's always a thrill getting the old one out when they break. It is 1/4-20 thread and takes a 7/16" open end wrench and a 1/8" allen wrench. Share this post Link to post Share on other sites
bunson70 51 #16 Posted March 17, 2011 My screw broke off in my Command 8. I was lucky and was able to get it out. Does anyone know the part number and where I can buy one? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #17 Posted March 17, 2011 Does anyone know the part number and where I can buy one? As previously stated; dog point set screw, 1/4 - 20 threads, and around 1.25" to 1.5" long. Try hardware suppliers like Fastenal, Grainger, McMaster-Carr, etc. if you don't want to buy one from Toro. Share this post Link to post Share on other sites
baerpath 517 #18 Posted March 20, 2011 Ace Hardware, TrueValue both have them in assorted sizes. Ace even had them in stainless. Duane Share this post Link to post Share on other sites
bunson70 51 #19 Posted March 20, 2011 I'll try that! Thank you guys!! :thumbs: Share this post Link to post Share on other sites
bunson70 51 #20 Posted March 26, 2011 I found the dog point screws at Fastenal. They call them full dog point. Their part number is : 25393. The description is 1/4-20 x 3/4. I had to purchase the nut seperate. The price was like $1.31 each. I hope this will help. Share this post Link to post Share on other sites
