formariz 12,381 #1 Posted February 5, 2010 Does anyone have a photo of what the charging coil looks like on a H-60? Share this post Link to post Share on other sites
420lse 18 #2 Posted February 5, 2010 Hi Cas I think I found this here on the RS site. Hope it helps. http://home.earthlink.net/~edstoller/id11.html Moe in CT Share this post Link to post Share on other sites
HankB 28 #3 Posted February 5, 2010 Hi Cas I think I found this here on the RS site. Hope it helps. http://home.earthlink.net/~edstoller/id11.html Could have been me that posted that link. I did so WRT the diode replacement he describes lower down. I did that repair on an A-80-E and it solved the "not charging battery" problem. A pair of diodes cost me almost $2 at Radio Shack. Three days later I found the same diodes on the shelf at American Science and Surplus for $0.20 each. I got so excited about that that I bought $2 worth and offered pairs to anyone on RS who wanted them. Sadly, no one ever took me up on the offer (which still stands) and the diodes are sitting next to me on a table collecting dust. Incidentally, I contact the guy that put that information up and he has a GT-14. Share this post Link to post Share on other sites
formariz 12,381 #4 Posted February 5, 2010 Unfortunately my issue is not the diodes.I have dozens of the original ones. It is definitely the charging coil since there is 0 AC voltage coming from coil into the regulator. Short of a hidden broken wire it is definitely the charging coil.I want to know what it looks like so I obtain one prior to taking the flywheel off so I don't go through all the work twice or have a dismantled engine for a while. Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #5 Posted February 5, 2010 Here you go, Cas: Share this post Link to post Share on other sites
formariz 12,381 #6 Posted February 5, 2010 Yes! Just like old faithful.I was wondering where you were. Manny thanks TT Share this post Link to post Share on other sites
formariz 12,381 #7 Posted February 7, 2010 TT Does that coil have two or just one post between the two coils? The mounting post is obvious but I don't really see another one. So far all the replacement coils I found have two posts. They all seem to be Tecumseh part # 61111. Would they work if in fact they have an additional post, probably making the whole assembly longer? Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #8 Posted February 7, 2010 It only has the one projection where the mounting bolt is located with one charging coil post on either side. I have another coil assembly around here somewhere I'll check out - IF I can find it. B) Share this post Link to post Share on other sites
Michael Bullington 5 #9 Posted February 9, 2010 i would think there is a wire touching or broken somewhere, there isnt a hole lot that can go wrong, I did have to replace the small pads under my coils once due to a similar problem...I would remove them clean the poles real good,,,replace the pads and see what happens. (Rememeber when you remove the bracket to mark where the bolts are...this is how the timing is set good luck Share this post Link to post Share on other sites
buckeye 5 #10 Posted April 21, 2010 Here you go, Cas: i have been searching for hours. and this pic looks like my unit, minus the coils on the stator. it's from a L-157. so would that mean that this is not original? i'm just finishing a rebuild of an h-60, and i would be heartbroken if i cannot recharge a battery. any input or pics of the wiring of the charging system would be appreciated.(and i have already looked at every wiring schematic out there). i started to wonder when i looked at the rectifier board, and realized there are no wires coming from my ignition system to hook them too. f*****g tecumseh is giving me a headache. if nobody can help, at least give me a for trying to figure out a damn tuccky, :omg: Share this post Link to post Share on other sites
sorekiwi 761 #11 Posted April 22, 2010 I have one that was on an H60, and it looks to me to be identical to Terry's. Share this post Link to post Share on other sites
buckeye 5 #12 Posted April 22, 2010 are looking to get rid of it? Share this post Link to post Share on other sites
sorekiwi 761 #13 Posted April 22, 2010 are looking to get rid of it? Sorry, probably not. There's a slim chance that maybe I'll find a block to suit that engine and put it back together. Share this post Link to post Share on other sites
