Iggy68 28 #1 Posted January 17, 2010 I am at my wits end I can't get this thing to run. I have spark, fuel, and air. I have gotten it to run barely. I had to hold my hand over the choke opening to block off incoming air to get it to fire. I have checked the points and have set them to gap and fire at top dead center. Is there any other timing on this thing that I am not aware of? It is flooding very easy. This engine has not ran for 15 years, new coil, new plug, new wire. The only thing I have not change is the points. Any suggestions? When I did have it running it was blowing black smoke. :WRS: Share this post Link to post Share on other sites
Indy w h 5 #2 Posted January 17, 2010 You might start by draining out the old gas then take off the carb and take it apart and spray some carb cleaner in it. Sounds like it's just gummed up from sitting so long. Give it a try and report back. Good luck !!! Indy Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #3 Posted January 17, 2010 I looked at your pictures and assume that you never opened the engine up, so cam timing shouldn't be an issue. Did you happen to check the valve clearance while it was apart? Points should be set at the baseline measurement of .020" when they are fully open. I have never bothered with checking piston position when setting the point gap on a stock engine, and honestly don't think you could without a degree wheel. Are you still working with the old carb? As Indy said, it might be gummed up from sitting and need a good soaking. Share this post Link to post Share on other sites
Iggy68 28 #4 Posted January 17, 2010 Thanks guys, I put a new carb on it. I just pulled the head off, that was the only thing I took off of the engine. I had put a new gasket on it when I put it together. It was not making sense to me that I could get it fire by cutting all the air of through the carb. As I suspected it was sucking air through the head gasket. I just went and got silcone gasket sealer. I will let you know if this solves the problem. :thumbs: Share this post Link to post Share on other sites
rickv1957 77 #5 Posted January 17, 2010 Silicone is not a very good fix for a head gasket,Rick Share this post Link to post Share on other sites
Iggy68 28 #6 Posted January 18, 2010 I was looking at the wiring diagram for this and it shows a condenser. It did not have a condenser on it when I got it, what does the condenser do and should I get one? Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #7 Posted January 18, 2010 The condenser is basically a capacitor used to store the "surge" of electricity at the breaker point contacts caused when the primary field collapses in the ignition coil. Long story short..... It prolongs the life of the points by decreasing the arcing at the contacts, which will burn them away over time - and yes.... your tractor engine needs one. Share this post Link to post Share on other sites
d180man 5 #8 Posted January 18, 2010 Silicone is not a very good fix for a head gasket,Rick HI i am with rick ! i think i would get a new head gasket and check the head but good luck ! on it ! :banghead: Share this post Link to post Share on other sites
rickv1957 77 #9 Posted January 18, 2010 Condenser attaches to neg side of coil,Rick Share this post Link to post Share on other sites
tgranthamfd 29 #10 Posted January 18, 2010 I'm with them, a good carb cleaning and DO add the condinsor. Recheck head gasket and the head. They will start and idle without a condinsor but cut out, smoke, back fire, and run like crap when on the throttle. Broke a condinsor wire once. :thumbs: Share this post Link to post Share on other sites
Iggy68 28 #11 Posted January 18, 2010 Thanks guys, the points are the only thing I have not replaced. Guess I will go get them and aondenser. I did a more careful exam of the head and found a corner that had the slightest warp. 45 minutes later warp was gone, lots of sanding on a nce flay surface Wish I would have checked better the first time. Share this post Link to post Share on other sites
buckrancher 2,697 #12 Posted January 18, 2010 When you had the head off did you check and make sure the valve's were both closing completely also the carb may be plugged from gum deposits in the main venturi tube from sitting so long and yes you do need a condenser Share this post Link to post Share on other sites
Iggy68 28 #13 Posted January 20, 2010 First thing I want to say tonight is a big to a great group of guys here at Red Square. I am simply amazed at the amazing amount of knowledge that is on this site. The knowledge is only as good as the willingness to share it. All of you guys do a fantastic job at that. Let's get to the news, I picked up a new set of points and the missing condenser today. I had to go visit a josite and the parts store was on my way, so I stopped and got em. Had to wait 5 hours to come home and put them in Got them in tonight, set the gap, reset the idle screws to factory set on the carb, turned the key on, pushed the start button and the 47 year old kohler that has been sitting for 15 years fired right up. I thought I would be smart before I started and check the spark compared to the other night, big mistake, shocked the living sh!t out of myself. It purrs like a kitten I have to say. I would have probably struggled for a couple more days without the help from you guys. once again. Share this post Link to post Share on other sites
rickv1957 77 #14 Posted January 20, 2010 Mark,thats great!, Rick Share this post Link to post Share on other sites
C-85 829 #15 Posted January 20, 2010 What a test, a shocking test that is! A lot transpired on this subject before I got a chance to look at this. While I was reading this I was heading on blaming the won't start issue on compression and with a slight head wrapage problem that would do it. This should have had at least a 100psi of compression to run. I also was wondering about the spark and timing. I use a wide gap spark plug to test spark, if that gives no spark and won't jump the gap, then there is ignition problems. Good luck! C85 Share this post Link to post Share on other sites
bork 0 #16 Posted January 20, 2010 Hehehehe Havn't been zapped in a while! Know the feeling well.! Now you should be a wake! I wished I coulda read this earlier also. I did all the same to my K241 , because it sat long also. I cleaned out tank & replaced all fuel lines & fuel pump & cleaned out carb/jets. Starting fluid is great for diagnosing also. If you can get engine to run on it,(start & some idling) usually indicates fuel problem. (just be carefull of its flamability) Share this post Link to post Share on other sites
