Horse Fanatic 51 #1 Posted January 2, 2010 I was looking for something to do today and I had an NOS older style rear lift bellcrank I got cheap but it won't work on my newer tractors. So I modified it so I could use it. First was to remove the second lever, then shorten the 3/4" shaft. Then I put the notches in it for the chain. Since this was a thinner lever I thought I should widen it (like the newer ones were) because the notches weaken it. I welded a piece of key stock on the back to beef it up. The only thing left, since I can't really put the groove in for snap rings, I will drill holes and use a cotter or hitch pin to hold the rod in place on the fender stand. Share this post Link to post Share on other sites
rickv1957 76 #2 Posted January 3, 2010 Good work there Glen,Rick Share this post Link to post Share on other sites
bitten 134 #3 Posted January 3, 2010 Glen If you can get it into a drill press and chuck it up you can use one tooth of a hack saw blade to cut the groove.I say one tooth because if you use more it might cut it to wide. It worked for me. Share this post Link to post Share on other sites
