stevebo-(Moderator) 8,609 #1 Posted December 21, 2009 Guys, Go the 314 in paint and putting back together. I need help with adjusting the carb & govener linkage. I would like a close up pic of another 314-8 (1993) if has one. This will help me make sure the rotation on the linkage is correct. if you have a diagram of the carb linkage that would be best. Every time I adjust the cable linkage the throttle goes from low rpms right to wot there is no way to slowly rev it up using the throttle cable. The other issue is I cannot get it just right so when wot it reve around 3400 rpm. The manual is really bad as it only tells you to adjust the carb but not how to... thanks- steve bo Share this post Link to post Share on other sites
Curmudgeon 28 #2 Posted December 21, 2009 Wish I had pic.... The way it's acting, it's obviously hooked up wrong. Been there, done that. NOT telling you a darn thing am I??? If no pictures come forth, take a close look at the way it's acting, sometimes if you just watch the action real close, you can see where the flaw in the hook up is. Hope the luck is with you!! Share this post Link to post Share on other sites
rickv1957 77 #3 Posted December 22, 2009 Steve,I can get you a picture tomorow if you still need it,Rick Share this post Link to post Share on other sites
stevebo-(Moderator) 8,609 #4 Posted December 22, 2009 Rick, That would be helpful. I know it is something very simple however Cannot figure it out right now. Share this post Link to post Share on other sites
rickv1957 77 #5 Posted December 22, 2009 Steve,will have pix in the AM,Rick Share this post Link to post Share on other sites
rickv1957 77 #6 Posted December 31, 2009 Steve,here is a couple of pix,not the if more is needed let me know,Rick Share this post Link to post Share on other sites
