~ETC~ 0 #1 Posted December 9, 2009 OK i have 2 wheel horses. a b-111 and a b-81 both have the 4 speed uni drive both have sloppy/wobbly axle shafts were there once bearings in the ends of the axle housings or just metal sleeves? how have others repaired this sort of problem? on both WHs when i tore the transmissions apart i found remnants of possible bearing cases/ sleeves their so far gone i cannot tell what they once were Share this post Link to post Share on other sites
Save Old Iron 1,571 #2 Posted December 9, 2009 I just guessing here - but the bearings and bushings probably disappeared somewhere along this timeline - from your website how have others repaired / avoided this problem ?? not this way, wee laddie. (again, from your website) use your model and serial numbers - go to the toro website and order / download a repair manual for the transmissions. search this site for bearing and seal replacement part #'s that can be ordered from NAPA or TORO Share this post Link to post Share on other sites
Coadster32 793 #3 Posted December 9, 2009 Cool pics but..... I don't think by destroying tractors, you'll make ton of freinds on this site. Good luck. Share this post Link to post Share on other sites
JimD 3,347 #4 Posted December 9, 2009 Cool pics but..... I don't think by destroying tractors, you'll make ton of freinds on this site. Good luck. on the other hand, he may have parts for sale shortly.... to answer the op's question, yes there were definitely bearings there before. Share this post Link to post Share on other sites
chris11 184 #5 Posted December 9, 2009 well one thing is the top picture the engine is sitting the right way Share this post Link to post Share on other sites
rickv1957 76 #6 Posted December 9, 2009 I guess that is one way to change to a horizonal shaft!,Rick Share this post Link to post Share on other sites
sawhorse 0 #7 Posted December 10, 2009 In other words, you have taken two wheel horses hostage. In order for them to be returned unharmed, we need to disclose the information. Share this post Link to post Share on other sites
~ETC~ 0 #8 Posted December 14, 2009 THE REASON WHY IM RESTORING MY SECOND WH IS BECAUSE THE FIRST ONE (THE BLACK/RED/ORANGE ONE PICTURED) HAS SURVIVED SO MUCH. where can i buy the bearings? and how are they installed Share this post Link to post Share on other sites
chazm 413 #9 Posted December 14, 2009 Dude ...like it said in an earlier post use your model and serial numbers - go to the toro website and order / download a repair manual for the transmissions. search this site for bearing and seal replacement part #'s that can be ordered from NAPA or TORO :thumbs: Share this post Link to post Share on other sites
Buzz 502 #10 Posted December 14, 2009 According to Toro's website, both the B-81 and the B-111 have Peerless 669 transmissions, not Unidrives. I don't know if you can get parts to rebuild them or if it would be worthwhile . You can always download a manual to see if it's something you'd want to try. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #11 Posted December 14, 2009 Illustrated Parts List (.pdf file) Some parts are still available through authorized Tecumseh dealers. Share this post Link to post Share on other sites
