MaineDad 87 #1 Posted February 21, 2008 Guys, Last night I removed the gas shock and replaced it with a new clutch spring. That dang shock was so bad that I did not have any control with releasing the clutch. What a difference that spring makes. Now I have to re-adjust the brake. Anyone else done this too? Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted February 21, 2008 This was just discussed over at the big Yahoo! group about 5 days ago It was a bit of a different problem, but still the same area. I know it certainly helps cut down on unexpected wheelies, and it allows smoother engagement, which means less "shock" to the transaxle. Another person even recommended periodically checking the four bolts that join the transaxle to the frame mounting plate. (which is good practice anyway!) The gas spring discussion seems to come up alot, and the best thing I can recommend is exactly what you've done with yours. Here's what he was up against though: " My 312-8 purchased new in 2000 has started experiencing main drive belt problems. It broke a couple winters ago while blowing snow. Now, only a couple years later, it is very worn and slips off the pulleys at the worst possible times (blowing snow, at the end of the long drive, in the cold, etc). Snow does get packed into the housing below the seat and shifter housing (and stays there, as it is stored in an open shed with no heat). Might this be impacting a return or tensioning spring, or is there something more fundamental that needs to be addressed? This does not seem to be a warm-weather problem... Jim" "Jim, I think you may have a problem with your idler pulley, or possibly the metal tab that keeps the belt on it. You also may want to check the belt shield. It is very rare that you should be replacing the drive belt that often. Blowing snow really does not put a huge demand on the transmission either, not as much as say pushing a plow. I have a C125 8 speed that The drive belt is about 10 years old on. I plow with this machine and have not ever had any problems. Check those areas, I'll bet you find your problem in there. Jack" "In addition to what Jack is saying, you should go to your Toro dealer and purchase a P/N 108035 spring. (about $5.00) (buy a P/N 93-9808 belt while you're there too -- about $28.00) Install the spring from the small hole in the clutch arm (left side of tractor -- under the rear fender) to the small hole in the left axle housing on the transaxle. Remove the gas spring on the right side of the tractor. (it connects from the tensioner pulley arm to the tractor frame) Throw the gas spring unit in the trash. Unbolt the idler pulley and install the new belt. Do not bend the tab on top of the idler pulley arm to install the belt! Terry" "Thanks to both of you. As I was putting the new belt on, I looked at that tab that holds it on, and recalled that during the first belt (which had broken) replacement, in the snow and cold, I bent that tab up a bit to get the new one on...and did not bend it back. That now looked like a problem and apparently it was. Also, as I was looking things over I wondered where and how a spring might be attached. Sounds like Toro worked something out for me on that, and I will get the part as soon as I get to my distant Toro dealer...or improvise something in the meantime. Jim" Share this post Link to post Share on other sites
kpinnc 17,126 #3 Posted February 21, 2008 Gas shock? Is that something used on the newer machines? I've never seen one. Kevin Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,752 #4 Posted February 21, 2008 Micah, I had a couple of threads about this for my '98 314-8. Here they are: Clutch spring fix finding the problem And here's one more: Clutch Spring Adjustment? Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,752 #5 Posted February 21, 2008 Gas shock? Is that something used on the newer machines? I've never seen one. Kevin Kevin, Yes some of the newer models used this setup. They tend to get weak - think gas shock on a rear hatchback. :thumbs: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted February 21, 2008 Gas shock? Is that something used on the newer machines? I've never seen one. Kevin I believe they were used starting in 1991. The damper mounts between the idler pulley arm and the frame and is supposed to dampen the clutch action. (So you can't "pop" the clutch and cause the tractor to flip over backwards, I guess. (More safety issues & lawsuits, I suppose?) It was my understanding at first, that the damper (now installed on the right) actually replaced the "real" spring on the left side of the tractor, but it looks like they were both on there together. There is a conversion kit available for all of the 300 series "Classic" gear drive tractors, but I wouldn't know why you'd actually want one. By the way -- a new-style replacement damper (P/N 100-8732) is over $82.00 and the old-style (P/N 78-3240) is around $47.77! P/N 104-5095 kit: Share this post Link to post Share on other sites
MaineDad 87 #7 Posted February 21, 2008 Terry, Thanks for the links. BTW did you ever figure out how to fix your brake? Mine is really loose and the adjustment nut is tightened all the way. The brake pedal is resting all the way back towards my foot instead of more forward like the clutch does. Maybe time for a new brake band? Micah Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,752 #8 Posted February 21, 2008 TT, On my 314-8 that spring was not there. The holes and the notches were there but not the spring. I just found a replacement off a JD parts tractor and it worked, for the time being. I might go buy the real one, though, someday. :thumbs: Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,752 #9 Posted February 21, 2008 Micah, No - it stops so I haven't looked further into it. I need to do that though as, in my unskill opinion, the petal is too high. :imstupid: Share this post Link to post Share on other sites
kpinnc 17,126 #10 Posted February 21, 2008 Looks like it would make clutching a pain for sure. Especially when it started to wear out. Thanks for the info! Kevin Share this post Link to post Share on other sites
