Helmer 0 #1 Posted November 26, 2009 I need a to replace the rectifier on my C-101 with 10 HP Kohler due to the center terminal being burnt or corroded away. These units are crazy expensive to buy new. Is there a way to bench test a used one to make sure it's good? I need to find a good used one. Thanks for any help. Share this post Link to post Share on other sites
rickv1957 76 #2 Posted November 26, 2009 You can a used unit on ebay pretty easy,Rick Share this post Link to post Share on other sites
Save Old Iron 1,571 #3 Posted November 26, 2009 buy a 24 volt transformer at radio shack and connect the 24 VAC leads to the AC leads of the rectifier - this will simulate the stator output - - then measure with a dc voltmeter from the case ground of the rectifier to the DC output (usually center terminal) on the rectifier / reg assembly you should see around 14. 5 volts + or - about .5 volts. this will not test the voltage regulation at a high current load - you would need a very high amp 24 VAC transformer and a large resistive load to simulate large current loads thru the rectifier. it can be done - it's just more expensive to accomplish than buying the reg / rectifier assembly to begin with Share this post Link to post Share on other sites
Save Old Iron 1,571 #4 Posted November 26, 2009 helmer, just a thought - if you still have some metal left on the center terminal , you might be able to solder a wire directly to the terminal and still utilize the current rectifier assy. again - just a thought :notworthy: Share this post Link to post Share on other sites
Helmer 0 #5 Posted November 27, 2009 Thanks Chuck. I think there is enough of the terminal tab to make a new connection. I'll give it a try. If that doesn't work I'll check on ebay. Share this post Link to post Share on other sites
