tophatbufflo
14 Auto Hydro
tophatbufflo
My 14 auto sat all this summer. I installed a blade on it ans took it for a test drive and ound out reverse didn't work. I cheked the fluid and it was abit low so I filled it but no change. It is a 1-0435 with supposedly a piston type trans WH #5089 Any suggestion are appreciated
Sarge
Have you checked the nylon plate to see if it broke?
Sarge
Sarge
If the plate is in good shape not sure what to tell you. Might try changing oil/filter and run it a bit , maybe just a stuck valve.
Sarge
tophatbufflo
Sarge Thanks for your advice on my hydro I was working on it a warm day last week.I was trying to check the forward/reverse check balls but I couldn't get the screwdriver to turn them. My shifter pushed hard so I adjusted the friction mechanism out a turn and a quarter because it was all the way tight. I started it to check how easily it would move and my hydro was working again. Thanks for your advice. :thumbs:
KB9LOR
Sarge
Sarge, where is this nylon plate, been through the tranny manual and do not see it, can you help me out on locating it in the tranny?
tophatbufflo
On a 73 14 Auto it is part #130 in parts manual
