KB9LOR 4 #1 Posted October 22, 2009 As most of you know I have a Electro 12 Hydro, I have a 877 Hydro for parts, will the valve body work on the Electro? The Electro has a Sundstrand 90-2046 w hyd lift the 877 has a Sundstrand 3100077 without Hyd lift. Now from where I have been studying this for awhile and they look pretty much the same but the 877 has plugs where you would hook up for the Hyd lift, anyone know if swapping out the valve bodys would work? thanks! Share this post Link to post Share on other sites
refracman 167 #2 Posted October 22, 2009 All you need to do is remove the cones and springs from the 12 hydro and reinstall the in the other. Refer to the 12hydro trans manual and you'll see where they are located. As a side note the 877 pump could be a less volume pump, dont know for sure but could be. If all you'll be doing is mowing grass you probably will never notice but you really work it it could be noticable then. Share this post Link to post Share on other sites
Sarge 3,473 #3 Posted October 22, 2009 I'm pretty sure those are two different charge pumps, unless you swap the whole unit the valves may not work right. The Charger should be the later style with a T handle for the tow valve. Most of the '67 and older used a 1/2" cone-headed valve that had to be loosened for towing. Sarge Share this post Link to post Share on other sites
KB9LOR 4 #4 Posted October 23, 2009 They both have the same type tow valve, I thought of only using the valve body and not the pump, but I am pretty sure the pump is okay on the electro, as the lift workes perfectly, but on hills it will not climb them at all, I am gonna try to get to it this weekend, and the only thing it will be used for is mowing. and thanks for the info it helps alot! Share this post Link to post Share on other sites
