BPEisenhower
Charger 12 Automatic with a 14 HP wiring help
BPEisenhower
Good morning Horse Family 😁. Rainy and cool but that's not stopping me. I've posted pictures of this machine a few months ago and did get snow blade attached, motor running and tested hydraulics. So far, it's a keeper! However, I'm thinking the extra engine I got with it is the correct one with the electronic magneto mounted on the shroud. The problem is the wiring is a nightmare, got a push button for a Killswitch going to the coil (pointless in my opinion) the battery is run directly to the key switch as well as the starter. Shouldn't there be a solenoid in between battery and starter? I have another good key switch since the one currently on it is melted from WAY too much current and the rest of the wires are like a bowl of spaghetti. Shouldn't I be able to put a solenoid of some type on and run new wires the correct gauge to everything? If not a five prong switch, then possibly a different setup using any switch with a push button starter? Thank you for your assistance! And no, I won't be using the rear tires on it now, I w patched enough holes in tubes that it would have been easier to have gotten new shoes in the first place 🤣
pfrederi
Your Charger 12 originally ran full starter current through the ignition switch no solenoid.  Guess they tried to reuse the switch with the new emgine.  By all means get a new 5 terminal batter ignition switch and a solenoid.
ri702bill
Homebrewed wiring is always the scariest maintainence "upgrade" on these old girls. My alltime favorite is when folks use siamesed 110 volt lamp cord in the wiring harness... just ask @Sparky.....
953 nut
? ? ? ?   Are you planning to continue using the battery ignition engine shown in your photo   OR  use the breakerless ignition engine mentioned in your post?  I am attaching wiring diagrams for both. Whatever you decide to do be sure you do not allow 12 volts to make contact with the wire coming from "electronic magneto mounted on the shroud" breakerless can.  You would be best off buying a 5 pin harness as shown below, the connecters that are on your switch do not hold as well as the Packard 56 connecters used in the harness and the wires are protected from shorting to one another.
shopping?q=tbn:ANd9GcTWuHTjUjKroV_0vLket_lF1Cp6tdDoCb5QipEc-hrjcycbXbFaDzo32zxutx_eSFJHX1W9KpBxsZgptH8-2Qmf9Pw2cgM_9absnY-pna1T-x44OlQQMY4i41_5MWJM&usqp=CAc
As for the extra ignition switch you have do you have a number on it?
This drawing is for the battery ignition as shown using a 103990 ignition switch with a solenoid.
This drawing is for the breakerless ignition on your extra ignition using a 103991 ignition switch and a solenoid.
Here is an illustration of the types of ignition Kohler used.
If you wire the ignition for battery ignition and change your mind later and go to thr breakerless later on you can add a kill relay (about $ 10.00) later on rather than a new ignition switch and some rewiring.
BPEisenhower
I will be using the coil and breaker ignition. That's what the 14 HP has that is in it now. Can't find any numbers on the ignition switches but, the one on the left with the terminals with screws is what was on it and the one to the right come from an Automatic 12 Charger that was for parts since there was no motor. I also have heavy duty solenoids for snowplows I can use since there's plenty in the shop 😁
