Bill D 3,212 #1 Posted 3 hours ago I recently picked up a used trailer that needs some work. The wiring is not up to my standards. Does anyone here have a reliable source for quality trailer lights and wiring? Thanks. Share this post Link to post Share on other sites
ri702bill 13,378 #2 Posted 2 hours ago Have you seen the wireless magnetic LED ones? Pretty impressive. The transmitter plugs into a standard 7 way socket. That gets you everything including plate light. Sorry, no backup lights. But hey, if you can maneuver a trailer, who needs backup lights?? 1 2 Share this post Link to post Share on other sites
ebinmaine 81,258 #3 Posted 2 hours ago IMHO and experience your best bet is to get NOS lights and shop carefully for wire. Here's a thread from a few months ago about wire: Get FULL COPPER wire. I'm not a fan of CCA which is Copper Clad Aluminum. As I stated in the thread those are metals that don't play well together long term. If it's a single axle trailer with no brakes you'll need standard 4 conductor wire. If you need 7 conductor wire there's a link in that thread to where I bought mine for the truck. If you don't normally keep wire in stock, let me know how many feet you need. I'll check here. 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,925 #4 Posted 2 hours ago (edited) 21 minutes ago, ri702bill said: Sorry, no backup lights. I have not used these, but they have back ups I have wired magnetic lights that I can store inside and use on multiple trailers and are easily removed when I dunk my boat trailers in salt water. Amazon.com: AosKe Wireless Trailer Lights - Magnetic Trailer Lights Retroreflectors, Portable Universal Stop Turn Running Backup Reverse Red, Tow Lights LED Kit for Trucks, Boat, RV, Vehicle, Caravan : Automotive My next set will be wireless magnetic lights. Edited 2 hours ago by Ed Kennell 2 1 1 1 Share this post Link to post Share on other sites
953 nut 70,610 #5 Posted 1 hour ago 33 minutes ago, Ed Kennell said: My next set will be wireless magnetic lights. I would probably forget to charge them up or put them on the wrong side of the trailer, but I'm sure the nice offiver would understand. 1 1 Share this post Link to post Share on other sites
ebinmaine 81,258 #6 Posted 1 hour ago I like the idea of magnetic lights quite a lot but I wouldn't consider them to be a permanent solution up here with the rough roads. The magnets would NEED to be extremely strong. 1 Share this post Link to post Share on other sites
Ed Kennell 47,925 #7 Posted 1 hour ago (edited) 15 minutes ago, ebinmaine said: rough roads. I used steel channel to make a box that mine sit in. The set I use has the front amber lens. I mount them so it can be seen from the front so I know they are working. Edited 1 hour ago by Ed Kennell 1 1 1 Share this post Link to post Share on other sites
953 nut 70,610 #8 Posted 1 hour ago I used magnetic lights on my old trailer and used tie wire to more or less permanently attach them to the sides of the ramp up near the top. 1 Share this post Link to post Share on other sites
