CRF857
520 mower deck clean up
CRF857
Recently dropped the deck off of the 520H. Pressure washed it. Removed the blades and covers, and cleaned up any excess grease/crud. Removed all the rollers and wheels. Cleaned the ores with a small “bottle brush” style wire brush, wire brushed the axles and reinstalled them all with as much “red and tacky” grease as I could pack into them. With the blades off I used a drill and socket to spin the bearings. Super quiet. Even the idler. Put it all back together and setting it to the side until next spring. Bought this unit last spring. P.O. said it had been recently rebuilt. Blades will need sharpened since the did a lot of mulching this fall.
Next up will be the deck off of the C141.
Edited by CRF857
CRF857
Wouldn’t load pictures.
  • Sad 1
ri702bill
Pete's second favorite! Because it works...
Edited by ri702bill
peter lena
@ri702bill  my favorite is lucas  EXTRA HEAVY DUTY , GREEN CHASSIS GREASE . specs alone , at 550 deg drop point , polyurea rated  stays with bearing , anti sling , never had a bearing fail with a clean out and re grease . when you do a mower deck spindle bearings , and related , mule  drive 6203 bearings , as well  as pto lever start  area , then use , aramid  belts . from tractor supply , also  sun bake my decks , for penetrating oil , chain / gear  absorption , th transformation is amazing , never  burned out a clutch disc , spin up is very smooth / easy . love motion , detailing ,  hiding in plane site , pete
ebinmaine
Shrink em?
CRF857
1 hour ago, ebinmaine said:
Shrink em?
Just gave it another shot and they went right in
ebinmaine
Magic!!
Brockport Bill
good for you - - deck looks terrific -- maintaining a deck is one of best time investments to make for anything around the house or garage - - worth the time -- i have done the putty knife routine and pressure washer - or even the wire wheel as well as had some sand blasted to then paint etc -- certainly can be tedius but worth the energy - - a few weeks ago i had the 13 yr old grandsons to the bottom of my shell -- they didnt especially enjoy the dirty job but was good experince for them for future chores --------- heres photo of recent deck projects
ebinmaine
@Brockport Bill
If those kids get bored feel free to send em here. We got plenty for them to do.
:lol:
