CRF857 1,467 #1 Posted 3 hours ago (edited) Recently dropped the deck off of the 520H. Pressure washed it. Removed the blades and covers, and cleaned up any excess grease/crud. Removed all the rollers and wheels. Cleaned the ores with a small “bottle brush” style wire brush, wire brushed the axles and reinstalled them all with as much “red and tacky” grease as I could pack into them. With the blades off I used a drill and socket to spin the bearings. Super quiet. Even the idler. Put it all back together and setting it to the side until next spring. Bought this unit last spring. P.O. said it had been recently rebuilt. Blades will need sharpened since the did a lot of mulching this fall. Next up will be the deck off of the C141. Edited 3 hours ago by CRF857 2 Share this post Link to post Share on other sites
CRF857 1,467 #2 Posted 3 hours ago Wouldn’t load pictures. 1 Share this post Link to post Share on other sites
ri702bill 13,357 #3 Posted 2 hours ago (edited) 1 hour ago, CRF857 said: “red and tacky” grease Pete's second favorite! Because it works... Edited 1 hour ago by ri702bill Share this post Link to post Share on other sites
peter lena 10,119 #4 Posted 1 hour ago @ri702bill my favorite is lucas EXTRA HEAVY DUTY , GREEN CHASSIS GREASE . specs alone , at 550 deg drop point , polyurea rated stays with bearing , anti sling , never had a bearing fail with a clean out and re grease . when you do a mower deck spindle bearings , and related , mule drive 6203 bearings , as well as pto lever start area , then use , aramid belts . from tractor supply , also sun bake my decks , for penetrating oil , chain / gear absorption , th transformation is amazing , never burned out a clutch disc , spin up is very smooth / easy . love motion , detailing , hiding in plane site , pete 1 Share this post Link to post Share on other sites
ebinmaine 81,230 #5 Posted 41 minutes ago 2 hours ago, CRF857 said: Wouldn’t load pictures. Shrink em? Share this post Link to post Share on other sites
