1988_wheelhorse312 108 #1 Posted 6 hours ago So for everyone having the broken trunnion or bent pin problem this js what I came up with. Everything I did can be purchased at your local hardware store, out the door roughly for $20 dollars + JB weld if you dont have it laying ariund like I did. So to create this I drilled the hold out in the rockshaft arm that is closest to the pivot from a 7/16ths to a half inch. I installed a 2200lb working load drop forged 1/2 inch eyebolt with the shaft cut short enough to fit with several washers, and some grease. A few days before that I JB welded 2 3/8 washers into the eye on the bolt to act as a bushings to keep the adjustment eyebolt centered and allowed a couple days for it to cure. Then I added 3 fender washers with the side trimmed out to fit around the shoulder on the eyebolt. Lastly I bolted it on with a nylon lock washer so the bolt can rotate freely but there is no side to side play, and then locked it down with a second bolt. Works really good. The 90 degree side pull on that eye bolt is 25% of its 2200lb working load, making it 550ish lbs of side pull. The lift its self would probably break before the eyebolt. I created it this was for others to follow along who have minimal tool in their shop but need to solve this issue. Only real fail point is the 2 washers JB welded in to serve as a bushing. And if those fail, ill just take it to a shop and have it all welded together. I wanted to make sure I got this on the forum for those like me who spent 2 days searching all the corners of Google and this forum to try and find a legit solution to this problem. In the mean time Happy Horsing and Happy Thanksgiving! 2 1 Share this post Link to post Share on other sites
