HorseingAround 1 #1 Posted 18 hours ago i have this m14 kholer engine in one of my tractors. when i start it it runs fine and all but when i give the engine half or full thottel it stars trying to flood itself and spits out fuel out the carb i think it is smething with the govner or the linkage pls help me Share this post Link to post Share on other sites
rmaynard 17,654 #2 Posted 17 hours ago Sounds like a stuck float valve. 3 1 Share this post Link to post Share on other sites
Handy Don 17,716 #3 Posted 16 hours ago 1 hour ago, HorseingAround said: spits out fuel out the carb 31 minutes ago, rmaynard said: Sounds like a stuck float valve. Time to get the carb rebuild kit and a can of carb cleaner. Then do a thorough clean on the carb, replacing the float valve and float pivots with the ones in the kit 3 1 Share this post Link to post Share on other sites
Ed Kennell 47,875 #4 Posted 16 hours ago to the Follow the experts advice. 2 Share this post Link to post Share on other sites
953 nut 70,558 #5 Posted 15 hours ago There are several extremely small passages in your carburetor that must be clean to allow the carb. to work well. The carb. will need to be dipped in a carb. cleaner. Share this post Link to post Share on other sites
HorseingAround 1 #6 Posted 8 hours ago this is a band new carb hope its not that. i have spark i checked what else could it be?? 1 Share this post Link to post Share on other sites
rmaynard 17,654 #7 Posted 5 hours ago 3 hours ago, HorseingAround said: this is a band new carb hope its not that. i have spark i checked what else could it be?? Brand new Chinese carb? 2 Share this post Link to post Share on other sites
Ed Kennell 47,875 #8 Posted 4 hours ago 4 hours ago, HorseingAround said: his is a band new carb What was it doing before you installed the new carb? 1 Share this post Link to post Share on other sites
rmaynard 17,654 #9 Posted 4 hours ago Even a new carb, Chinese or otherwise, can have a stuck float valve. 1 1 Share this post Link to post Share on other sites
953 nut 70,558 #10 Posted 3 hours ago (edited) 5 hours ago, HorseingAround said: this is a band new carb hope its not that. i have spark i checked what else could it be?? 14 hours ago, HorseingAround said: i have this m14 kholer engine in one of my tractors. when i start it it runs fine and all but when i give the engine half or full thottel it stars trying to flood itself and spits out fuel out the carb i think it is smething with the govner or the linkage pls help me The NEW carburetors on the market today are frequently aggravating at best and a total waste of money in most cases. Your governor linkage will not cause the carb to "Spit Gas" but a poor adjustment or stuck float valve will. Have you adjusted the idle and main jets according to the Kohler manual? Look at pages 6-4 to 6-8 of the attached manual. Unfortunately many of the carbs from China try to fit engines from 10 hp to 16 hp by using the body from the #23 (10 to 12 hp) and the jets from a #30 (14 to 16 hp) and it will run but will never run well. As Bob @rmaynard just told you the carbs from Chia quite often have junk in the float bowl. They frequently will never perform properly but cleaning the float bowl may be a good place to start. Edited 3 hours ago by 953 nut fat finger 1 Share this post Link to post Share on other sites
