953 nut
Small tire changer on a budget.
953 nut
I have a home built tire changer for those 8" and 6" tires that works very well and is VERY low cost. The changer consists of a piece of 3/4" threaded rod about a foot long, two 3/4" nuts, a 3/4" fender washer, a 3/4" hole drilled through the work bench and a 3/4" rod coupler.
The portion of the 3/4" rod that is above the workbench needs to be about an inch longer than the hub width of your widest rim hub facing upward, longer is better than shorter.2034754064_smalltirechanger1.jpg.e317f5fe8153a7e3ade5d77685509677.jpg
Place the rim over the rod and tighten the washer and nut down to hold the rim firmly in place. I use a lid from a bucket to save the paint on the rim.
I use the thumbs or fingers from old leather gloves to protect the paint.
If you are going to use a tube in the tiere a couple of 4 X 4 scraps will come in handy.
  • Excellent 3
  • Thanks 1
