grinchsr 675 #1 Posted 6 hours ago Recently picked up a 516H for a good price with a deck. I thought all Onans had an oil filter this motor had none just a rubber plug in the hole (see pic) with some holes in it to run a remote oil filter I guess. I am thinking that it may be from another brand tractor or a replacement motor. The model and spec number did not tell me much maybe the Onan experts can find some info . Share this post Link to post Share on other sites
Streetrodchev 1,215 #2 Posted 3 hours ago Engine was built Nov ‘87, so it is a 1988 model year. Many times the 16hp Onan came without an oil filter. They have a plate bolted to the block. That can be replaced with a filter adapter and then put a filter on it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,547 #3 Posted 3 hours ago Here is an original parts manual 1 Share this post Link to post Share on other sites
grinchsr 675 #4 Posted 2 hours ago Thank you for the responses Share this post Link to post Share on other sites
Handy Don 17,703 #5 Posted 1 hour ago If you decide to run sans filter, it’d be wise to cover those holes to keep the engines cooling air flowing where it should--past the cylinder fins! Onan offered filter holders which were bolted to the engine (seen on WH 518s and 520s) as well as “remote” holders connected via tubing that used those holes. Share this post Link to post Share on other sites
