lorenzo
1970 electro 12 winter plowing
lorenzo
what's the best oil to use in a WH electro 12 tractor. I use it in the summer to move dirt and gravel and use it in the winter to plow the driveway. do I have to change weights between the summer and winter? Thanks
ebinmaine
You can run a good quality HD30 all year.
You can also switch to 10w30 if the machine starts hard in the cold with HD30.
Lots of "favorite" brands.
We use Kinetix. When that's gone I'll switch to Mobil One 10w30.
953 nut
:WRS:
If it is stored in an attached  garage you could probably be fine with SAE 30 all year long. 10 W 30 is recommended for cold weather use if stored outside or in a detached garage. Using an engine oil that has a high zinc content is recommended due to the engine have ing flat tappets, diesel rated oil or small engine oil from Briggs and Stratton or Kohler are well suited for this.
Briggs-Stratton-4-Cycle-48-oz-Oil-SAE-30-for-Small-Engines_0163fe72-3724-4ed3-84b4-f5a220785aac.088b508a6fd6beb9e59077a187d97000.jpeg?odnHeight=144&odnWidth=144&odnBg=FFFFFFWalmart has this in stock.
lorenzo
it came with a jug of Kubota 10w30 so I'm guessing that's what's in it now.
953 nut
If it is rated for diesel use it should be fine for winter.  Kohler engines tend to burn a bit more oil with 10 W 30 than with SAE 30 so when spring comes go to straight 30.
ri702bill
I use Rotella Conventional 10w30 in the winter, 30 weight in the summer.
sqrlgtr
Is it just me or should this thread be in another section. :ychain:
  • Confused 2
953 nut
You are correct but we need to give a newbee a little slack, besides the fact that I never even noticed the heading.  :confusion-confused:   I guess that snow plow could be used on some electric Wheel Horses.        :ychain:
Edited by 953 nut
  • Haha 1
sqrlgtr
@953 nut just thought it may get more views if it wasn’t in the electrical section and was in the engine or wheel horse tractor section.
ol550
It's an electro so it fits here.
  • Haha 1
Bar Nuthin
14 hours ago, lorenzo said:
:text-welcomewave:    If I had those hubcaps and that seat - and you had a feather in your shorts - we'd both be tickled! :P :ychain:
