lorenzo 2 #1 Posted 16 hours ago what's the best oil to use in a WH electro 12 tractor. I use it in the summer to move dirt and gravel and use it in the winter to plow the driveway. do I have to change weights between the summer and winter? Thanks 1 Share this post Link to post Share on other sites
ebinmaine 81,183 #2 Posted 15 hours ago You can run a good quality HD30 all year. You can also switch to 10w30 if the machine starts hard in the cold with HD30. Lots of "favorite" brands. We use Kinetix. When that's gone I'll switch to Mobil One 10w30. Share this post Link to post Share on other sites
953 nut 70,435 #3 Posted 15 hours ago If it is stored in an attached garage you could probably be fine with SAE 30 all year long. 10 W 30 is recommended for cold weather use if stored outside or in a detached garage. Using an engine oil that has a high zinc content is recommended due to the engine have ing flat tappets, diesel rated oil or small engine oil from Briggs and Stratton or Kohler are well suited for this. Walmart has this in stock. Share this post Link to post Share on other sites
lorenzo 2 #4 Posted 15 hours ago it came with a jug of Kubota 10w30 so I'm guessing that's what's in it now. Share this post Link to post Share on other sites
953 nut 70,435 #5 Posted 15 hours ago 7 minutes ago, lorenzo said: it came with a jug of Kubota 10w30 so I'm guessing that's what's in it now. If it is rated for diesel use it should be fine for winter. Kohler engines tend to burn a bit more oil with 10 W 30 than with SAE 30 so when spring comes go to straight 30. 2 Share this post Link to post Share on other sites
ri702bill 13,323 #6 Posted 2 hours ago I use Rotella Conventional 10w30 in the winter, 30 weight in the summer. 1 Share this post Link to post Share on other sites
sqrlgtr 4,193 #7 Posted 1 hour ago Is it just me or should this thread be in another section. 2 Share this post Link to post Share on other sites
953 nut 70,435 #8 Posted 1 hour ago (edited) 16 minutes ago, sqrlgtr said: Is it just me or should this thread be in another section. You are correct but we need to give a newbee a little slack, besides the fact that I never even noticed the heading. I guess that snow plow could be used on some electric Wheel Horses. Edited 1 hour ago by 953 nut 1 Share this post Link to post Share on other sites
sqrlgtr 4,193 #9 Posted 1 hour ago @953 nut just thought it may get more views if it wasn’t in the electrical section and was in the engine or wheel horse tractor section. 1 Share this post Link to post Share on other sites
ol550 880 #10 Posted 1 hour ago It's an electro so it fits here. 1 Share this post Link to post Share on other sites
953 nut 70,435 #11 Posted 1 hour ago 1 minute ago, sqrlgtr said: engine or wheel horse tractor section. Or one of the 1,723 or so "Best Oil" threads on here. https://www.wheelhorseforum.com/search/?&q=Best oil&search_and_or=and&sortby=relevancy Share this post Link to post Share on other sites
Bar Nuthin 3,545 #12 Posted 1 hour ago 14 hours ago, lorenzo said: If I had those hubcaps and that seat - and you had a feather in your shorts - we'd both be tickled! Share this post Link to post Share on other sites
