Silas Sealscott
I need help breakless ignition
Silas Sealscott
I have a 1970 wheelhorse electro 12 it has a 12ph k301 Kohler with the rare breakless magneto ignition system and I converted it over to point ignition from another later 12hp kohler and I don't know what ignition switch to get or if I can just use the old one and I don't have a wireing diagram and someone who had it before me put a starter solenoid on it. so if anyone has had the same problem or knows how to wire it up with the point ignition I would much appreciate it if you would help me so I can get this wheelhorse backup and running.
pfrederi
You will need to change to change the ignition switch.  Since yo have a solenoid for the starter a regular 5 terminal Battery Points switch will work.  103990 make sure it has an"I" terminal not an "M"
Silas Sealscott
do you know how I would go about wiring it
Ed Kennell
:text-welcomeconfetti:to the :rs:
pfrederi
Run a wire from the "I" terminal of the ignition switch to the small + terminal on the coil
gwest_ca
Since it has a solenoid added the ignition switch you have may be this one. They all look alike but the differences are the terminal locations and how they are labeled.
Original switch - heavy duty - click on the picture in each link to see more without downloading files
Magneto ignition light duty - if it is different can you post a picture of the back of it?
Battery ignition and very common
Silas Sealscott
I know what switch I need but I don't know how to wire it up because I converted the k301 with breakless ignition to point ignition if some one has a digram on how wire the tractor up after converting it it would help me out
Silas Sealscott
can I use this switch
gwest_ca
Yes that is a good one to use.
gwest_ca
If you can identify the wires on your present switch it is easy to change them to the correct terminals on the 103990. Using the plastic 5-wire connector body makes it fool proof in the future.
953 nut
Here is a drawing that can be used to wire the tractor since there are no safety switches. It uses the 103990 ignition switch. If you are using the electric PTO you can run a second fused wire from the "A" terminal to the PTO. Wire colors are up to you.
Silas Sealscott
thanks you this was what I was looking for
