Silas Sealscott 0 #1 Posted 2 hours ago I have a 1970 wheelhorse electro 12 it has a 12ph k301 Kohler with the rare breakless magneto ignition system and I converted it over to point ignition from another later 12hp kohler and I don't know what ignition switch to get or if I can just use the old one and I don't have a wireing diagram and someone who had it before me put a starter solenoid on it. so if anyone has had the same problem or knows how to wire it up with the point ignition I would much appreciate it if you would help me so I can get this wheelhorse backup and running. Share this post Link to post Share on other sites
pfrederi 21,307 #2 Posted 1 hour ago You will need to change to change the ignition switch. Since yo have a solenoid for the starter a regular 5 terminal Battery Points switch will work. 103990 make sure it has an"I" terminal not an "M" 1 Share this post Link to post Share on other sites
Silas Sealscott 0 #3 Posted 1 hour ago 16 minutes ago, pfrederi said: You will need to change to change the ignition switch. Since yo have a solenoid for the starter a regular 5 terminal Battery Points switch will work. 103990 make sure it has an"I" terminal not an "M" do you know how I would go about wiring it Share this post Link to post Share on other sites
Ed Kennell 47,820 #5 Posted 1 hour ago This may help.1970 electro 12 key switch - Wheel Horse Electrical - RedSquare Wheel Horse Forum Share this post Link to post Share on other sites
pfrederi 21,307 #6 Posted 1 hour ago Run a wire from the "I" terminal of the ignition switch to the small + terminal on the coil Share this post Link to post Share on other sites
Silas Sealscott 0 #7 Posted 1 hour ago 10 minutes ago, Ed Kennell said: This may help.1970 electro 12 key switch - Wheel Horse Electrical - RedSquare Wheel Horse Forum ok thanks but I don't know if it is the same because I converted the breakless ignition to point ignition. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #8 Posted 45 minutes ago Since it has a solenoid added the ignition switch you have may be this one. They all look alike but the differences are the terminal locations and how they are labeled. Original switch - heavy duty - click on the picture in each link to see more without downloading files Magneto ignition light duty - if it is different can you post a picture of the back of it? Battery ignition and very common Share this post Link to post Share on other sites
Silas Sealscott 0 #9 Posted 5 minutes ago 36 minutes ago, gwest_ca said: Since it has a solenoid added the ignition switch you have may be this one. They all look alike but the differences are the terminal locations and how they are labeled. Original switch - heavy duty - click on the picture in each link to see more without downloading files Magneto ignition light duty - if it is different can you post a picture of the back of it? Battery ignition and very common I know what switch I need but I don't know how to wire it up because I converted the k301 with breakless ignition to point ignition if some one has a digram on how wire the tractor up after converting it it would help me out Share this post Link to post Share on other sites
Silas Sealscott 0 #10 Posted 2 minutes ago 1 hour ago, pfrederi said: Run a wire from the "I" terminal of the ignition switch to the small + terminal on the coil can I use this switch Share this post Link to post Share on other sites
