Silas Sealscott
I need help breakless ignition
Silas Sealscott
I have a 1970 wheelhorse electro 12 it has a 12ph k301 Kohler with the rare breakless magneto ignition system and I converted it over to point ignition from another later 12hp kohler and I don't know what ignition switch to get or if I can just use the old one and I don't have a wireing diagram and someone who had it before me put a starter solenoid on it. so if anyone has had the same problem or knows how to wire it up with the point ignition I would much appreciate it if you would help me so I can get this wheelhorse backup and running.
pfrederi
You will need to change to change the ignition switch.  Since yo have a solenoid for the starter a regular 5 terminal Battery Points switch will work.  103990 make sure it has an"I" terminal not an "M"
Silas Sealscott
do you know how I would go about wiring it
Ed Kennell
:text-welcomeconfetti:to the :rs:
pfrederi
Run a wire from the "I" terminal of the ignition switch to the small + terminal on the coil
gwest_ca
Since it has a solenoid added the ignition switch you have may be this one. They all look alike but the differences are the terminal locations and how they are labeled.
Original switch - heavy duty - click on the picture in each link to see more without downloading files
Magneto ignition light duty - if it is different can you post a picture of the back of it?
Battery ignition and very common
Silas Sealscott
I know what switch I need but I don't know how to wire it up because I converted the k301 with breakless ignition to point ignition if some one has a digram on how wire the tractor up after converting it it would help me out
Silas Sealscott
can I use this switch
gwest_ca
Yes that is a good one to use.
gwest_ca
If you can identify the wires on your present switch it is easy to change them to the correct terminals on the 103990. Using the plastic 5-wire connector body makes it fool proof in the future.
