FLtractor 253 #1 Posted Monday at 07:26 PM Afternoon, I have attempted to step on pedal near pulley.. use clutch .. slip belt off by hand.. no luck. What is the best way to removal this belt and then replace ? Share this post Link to post Share on other sites
ri702bill 13,323 #2 Posted Monday at 07:46 PM Remove the idler pulley and its bent tab bracket. That should give you the slack needed to peel it of one of the pulleys - works on my 702 & 854... 1 Share this post Link to post Share on other sites
peter lena 10,115 #3 Posted Monday at 09:50 PM @FLtractor that belt fraying , reflects back on related , bearings , noisy / dry rough , incremental bearing stoppage , leads to belt bounce , fraying , everything looks bone dry . ever lubricate related linkage ? pete Share this post Link to post Share on other sites
FLtractor 253 #4 Posted Monday at 10:36 PM 2 hours ago, ri702bill said: Remove the idler pulley and its bent tab bracket. That should give you the slack needed to peel it of one of the pulleys - works on my 702 & 854... Thanks. Will give it a go Share this post Link to post Share on other sites
FLtractor 253 #5 Posted Monday at 10:37 PM 45 minutes ago, peter lena said: @FLtractor that belt fraying , reflects back on related , bearings , noisy / dry rough , incremental bearing stoppage , leads to belt bounce , fraying , everything looks bone dry . ever lubricate related linkage ? pete Have not lubricated since owned no.. Going to replace belt with new proper ribbed belt once I find out which model # I need from local NAPA. 1 Share this post Link to post Share on other sites
FLtractor 253 #6 Posted 2 hours ago (edited) On 11/16/2026 at 2:46 PM, ri702bill said: Remove the idler pulley and its bent tab bracket. That should give you the slack needed to peel it of one of the pulleys - works on my 702 & 854... I removed the center pulley and still can’t pull the belt off either of the 2 remaining pulleys Edited 2 hours ago by FLtractor Share this post Link to post Share on other sites
ri702bill 13,323 #7 Posted 52 minutes ago (edited) OK - it sounds like the belt MAY be the wrong size and a bit (1") too short, but yet it looks about right for length & width... What is the P/N on the belt? That IS an Early Tach-a-Matic implement mount, right, whereto deck drops out the bottom of the slot on both plates?? Very early ones did not - you had to remove the RH mount from the tractor & lift up to get the belt off. No slot - A real PITA. Edited 48 minutes ago by ri702bill Share this post Link to post Share on other sites
FLtractor 253 #8 Posted 38 minutes ago 12 minutes ago, ri702bill said: OK - it sounds like the belt MAY be the wrong size and a bit (1") too short, but yet it looks about right for length & width... What is the P/N on the belt? That IS an Early Tach-a-Matic implement mount, right, whereto deck drops out the bottom of the slot on both plates?? Very early ones did not - you had to remove the RH mount from the tractor & lift up to get the belt off. No slot - A real PITA. Since belt should be replaced anyway… Thinking of cutting the belt in half to get off pulley … I can then measure it.. should be 1/2 by 28 inches if not mistaken. not sure what to look for to tell if it’s tach o matic with the bottom slot. Share this post Link to post Share on other sites
ri702bill 13,323 #9 Posted 24 minutes ago Look at the inverted slots on each of the side plates to locate the front cross shaft... That is the later style. Mower Rotary 36in RD 1966 RM-366 _A-5252[1].pdf Share this post Link to post Share on other sites
adsm08 5,243 #10 Posted 12 minutes ago Place transmission in neutral, grab the slack portions of the belt in between the pullies with both hands, rotate the belt forward (clockwise) while pulling outward on the forward section. It will start to slip off over the edge of the pulley. Not ideal, but that one may not have enough give left in the rubber for it to come off the correct way. Share this post Link to post Share on other sites
adsm08 5,243 #11 Posted 10 minutes ago 41 minutes ago, ri702bill said: OK - it sounds like the belt MAY be the wrong size and a bit (1") too short A belt 1/2 inch short will fit properly, but cause the blades to not shut off fully and will be hard to install/remove. Share this post Link to post Share on other sites
