FLtractor
856 Deck drive belt removal
FLtractor
Afternoon,
I have attempted to step on pedal near pulley.. use clutch .. slip belt off by hand.. no luck. What is the best way to removal this belt and then replace ?
ri702bill
Remove the idler pulley and its bent tab bracket. That should give you the slack needed to peel it of one of the pulleys - works on my 702 & 854...
  • Excellent 1
peter lena
@FLtractor that belt fraying , reflects back on related , bearings , noisy / dry  rough , incremental  bearing  stoppage , leads to belt  bounce , fraying , everything looks bone dry .  ever  lubricate related linkage ? pete
FLtractor
Thanks. Will give it a go
FLtractor
Have not lubricated since owned no..
Going to replace belt with new proper ribbed belt once I find out which model # I need from local NAPA.
