Racinbob 13,278 #1 Posted 2 hours ago The balance gears on Dinos K-301 seemed to be rattling so I decided to just remove them. I was going to do a video but @Pullstart did one much better than I could. The link was posted a couple days ago but here it is again. What have you done to your Wheel Horse today? - Page 1078 - Wheel Horse Tractors - RedSquare Wheel Horse Forum First things first, drain the oil. I was surprised how dirty it was since it had well under an hour on fresh oil. I disconnected everything and hooked it up to the chain hoist. We have lift off. I had to jocky the tractor out from under it and around the hood. Next time somebody remind me to get the oil catch jar out of the way. I had about the same amount of rattle that Kevin had. His video shows best what I was dealing with. The bottom gear was easy. The upper not so much. I've got an assortment of snap ring pliars but nothing I had would do the job. I ended up getting a set of Icons and it then became easy. Except it wouldn't come off the shaft. I ended up driving the shaft out. That was one tight fit but it worked. Per Kevins video I drove the pin back in backwards taking advantage of the tapered end. Well, I almost drove it back in. I don't think that drive pulley would make it. I checked my stash and I do have a spare but I decided to remove it. Easier said than done but I'll get there. I don't think it's ever been off. Driving the pin into the engine was no problem with a large drift and sledge. The pin was recessed about 1/2" so I couldn't slip off. I've decided to start putting things back together as I wait for the penetrating oil to do its thing. It will also be easier to drive the pin with the engine mounted and held in place. Looking at the balance gears I can't help but wonder why Kohler spent so much money to engineer and install them. 1 Share this post Link to post Share on other sites
kpinnc 19,043 #2 Posted 3 minutes ago (edited) 2 hours ago, Racinbob said: First things first, drain the oil. I was surprised how dirty it was since it had well under an hour on fresh oil. Those oil pans tend to keep quite a bit of sludge in the bottom. No way to actually drain it all under normal oil changes. Good idea to clean it out (scrub with degreaser) really well while it's off. 2 hours ago, Racinbob said: Looking at the balance gears I can't help but wonder why Kohler spent so much money to engineer and install them. You won't notice much difference without them in a K301, so you'll probably think that even more so. On the other hand, on the K321 (14hp) and K341 (16hp) the vibration is more apparent. Especially true on the lower end of the power band. But- the peace of mind on these old engines is worth it in my opinion. Not unusual for big block Kohlers to have 1000+ hours on them, and those tiny bearings are the only wear point with such a high consequence with failure. You can break a rod without destroying the block and it is rebuildable, but if one of those bearings fail at high speed the block can be destroyed. In short, you definitely did the right thing. The only part I would do differently would be driving that top pin back in. I usually tap it in enough to seal in the oil and cut the rest off from the outside. Banging too hard on cast iron makes my knees weak... Edited 2 minutes ago by kpinnc Share this post Link to post Share on other sites
