Beap52
adding smoke to pellet smoker
Beap52
Now that cooler weather has arrived, I double smoked bacon that I have discussed here some time ago--and it got me to thinking.
I have a pellet smoker and one of the issues I see is that they don't infuse as much smoke flavor in food as my other smoker.   I've tried putting my smoke generator inside on the grill but it won't stay burning.  I assume lack of oxygen.
Today after removing the smoked bacon, I decided to try to adapt what I have on hand to produce more smoke in the pellet smoker.  I'll work on a better set-up if I proceed.  I am aware that there are commercially available smoke generators that can be attached to pellet stoves but what fun is that?
The first picture is the housing that I made to go around the smoke generator and the amount of smoke it produces.
I made a makeshift attachment that allows smoke to be drawn into smoker when the fan is running.
The third picture shows the amount of smoke drawn into the smoker via fan motor.
I don't think I'll be infusing too much smoke into the chamber.  The smoker doesn't produce a lot of smoke at lower temperatures and then only when the auger is dumping new pellets into the burn pot.
My concern/question is will drawing the smoke across the blower motor be an issue?  There is no heat with the smoke just smoke particles.  I don't plan to make it an airtight system just introduce smoke near the fan and let it draw what it will.
