Delkc01
HELP PARTS - Crankshaft, rod and piston assemblies
Delkc01
Can anyone help me location where I maybe able to purchase a crankshaft, rod and piston assemblies for a K181S Kohler 8hp engine I need to rebuilt?
953 nut
The Spec number,  30108D  is the most important information when looking for a crankshaft. We have a couple of venders here that you should start with.
K&B Horse Parts  @76c12091520h may have some NOS parts for the engine.
A to Z  https://a-ztractor.com/ will have used parts and may have NOS too. He sells on eBay but if you don't see what you are looking for give him a call.
ri702bill
You WILL need to know the bore size before ordering a piston & a set of rings... Standard bore, .010 over, etc.
If you plan to have the cylinder bored oversize, the Machine Shop needs those parts BEFORE they start... let THEM measure the bore to determine the correct size....
gwest_ca
Here is an original parts list if you need it
squonk
I have a crank. It may or may not need turning. You would need to get it checked. PM me if interested.
Fordiesel69
If you need to, the k181 can go. 020 under.  Often a machine shop can turn yours and then re fit the rod.  So if your only needs to goto 11 or 16 thou they can custom bore your rod.
I have 3 cranks.  All need turned WAY MORE.
oliver2-44
Before you buy parts, have you taken the block and crank to a show that machines small engines.
Buying a used rank in good usable condition is probable a challenge.
A shop may be able to grind you crank for less that buying one.
Delkc01
WOW....Thank you all very much for your replies and help here.  Sounds like the best option to start with is grinding down my crank, so I am going to start there and fingers crossed this repair my overall issue.
I will keep you all updated, and THANK YOU all again for your help here.
Delkc01
Hi again all - Where would you recommend I find/purchase the following for the same engine?
  • Standard size piston and ring set with new wrist pin and keepers
  • Complete gasket kit with crankshaft bearings
pfrederi
If your  machine shop has measured your block and says STD then I have used
lilredbarn.net also on ebay
