Delkc01
HELP PARTS - Crankshaft, rod and piston assemblies
Delkc01
Can anyone help me location where I maybe able to purchase a crankshaft, rod and piston assemblies for a K181S Kohler 8hp engine I need to rebuilt?
953 nut
The Spec number,  30108D  is the most important information when looking for a crankshaft. We have a couple of venders here that you should start with.
K&B Horse Parts  @76c12091520h may have some NOS parts for the engine.
A to Z  https://a-ztractor.com/ will have used parts and may have NOS too. He sells on eBay but if you don't see what you are looking for give him a call.
ri702bill
You WILL need to know the bore size before ordering a piston & a set of rings... Standard bore, .010 over, etc.
If you plan to have the cylinder bored oversize, the Machine Shop needs those parts BEFORE they start... let THEM measure the bore to determine the correct size....
  • Like 3
gwest_ca
Here is an original parts list if you need it
squonk
I have a crank. It may or may not need turning. You would need to get it checked. PM me if interested.
Fordiesel69
If you need to, the k181 can go. 020 under.  Often a machine shop can turn yours and then re fit the rod.  So if your only needs to goto 11 or 16 thou they can custom bore your rod.
I have 3 cranks.  All need turned WAY MORE.
