TC10284
108-5 pto safety switch
TC10284
I have a 108-5. Turning the key to Start does nothing. I have replaced the ignition switch and the solenoid with no luck. The wiring looks factory from what I can tell.
I can jump the solenoid and it starts fine. I can use the pull start and it starts fine.
On the voltmeter, I show 12.5v. As soon as I turn the key to Start, it drops to 0. Battery is good. But also tried booster pack just to be sure.
I suspect the pto safety switch or the neutral safety on top of the transmission. The pto safety switch I'm wondering if there is a cheaper option than $50 to $70
The part is listed here:
https://www.partstree.com/parts/toro-109327/
gwest_ca
Where are your tester leads when it drops to zero? Or are you watching an in dash voltmeter?
Share your model and serial number so we can look at the correct diagram.
ri702bill
A long shot here - but does that switch not look like a refrigerator door switch?? Perhaps a search of the actual part P/N can reveal its usage...
TC10284
I haven't got to the multimeter to test yet. Just watching the tractors own voltmeter and basing off experience from 300 and 400 series.
I would share the model/serial but it is faded off. I could share the engine model.
Edited by TC10284
TC10284
It does and that was a thought. I've searched for the part number on Google but only get Toro parts returned as results of course.
953 nut
On the voltmeter, I show 12.5v. As soon as I turn the key to Start, it drops to 0   This is normal, with the key in START the only connections being made in the switch are Battery and Starter.
With the key switch in the OFF position, PTO in the off position, and transmission in neutral, you can test the PTO switch  and the transmission switch with a multi meter. As you will see in the diagram the Tan and Purple wires of the PTO switch should have continuity and the transmission should have continuity between the two purple wires.
953 nut
An inexpensive multimeter will do the job.
Here is the manual for your Wheel Horse.
953 nut
The part number you were searching for has been superseded but the new number is also unavailable. Rather than spending money on replacing parts until you find the bad part please test the components first. Safety switch seldom go bad unless they suffer a physical defect by being hit by something. Occasionally the wires will become disconnected and simply plugging them back in will repair the problem. If the PTO switch doesn't test as being good we can help you find a STDP (single throw double pole) switch that will work   https://www.partstree.com/parts/toro-commercial-98-2392/
953 nut
Most refrigerator door switches are a single pole single throw normally closed with two wires going to it. The PTO switch is a double pole single throw switch with sic connectors allowing half of the switch to be N/O and half to be N/C. They may look alike on the outside but are ver4y different on the inside.
gwest_ca
If you post all the numbers off the engine including the serial number we may be able to determine the model number.
Will be like 190707-2154-01 plus the serial (1985) or
193707-0148-01 plus the serial (1986-1988)
TC10284
I got my multimeter out and with the wiring diagram I found out I was getting 13v all the way to the end of the wire off the transmission neutral interlock safety switch thing.
The problem was in the wire coming off the other side of the solenoid terminal that runs down to the threaded stud on the mower deck. I temp connected a jumper wired from the other terminal of the solenoid to a different ground and it fired right up with the key switch. So I made another wire and ran it to another chassis ground under the seat.
I don't really understand why they put the starter solenoid ground wire to the mower deck at the factory, but maybe I just don't know their reasoning.
Regardless, it appears to be resolved. Thanks!
Edited by TC10284
953 nut
I'm glad that little bit of troubleshooting rot you going. to me all grounds should go to the battery negative or the frame.   :scratchead: I totally agree with you, having a ground wire go to the deck which can be moved up and down is ridiculous      :twocents-02cents:.
TC10284
As always, you guys are very helpful and get me to a solid resolution, and I greatly appreciate that.
