TC10284 121 #1 Posted 2 hours ago I have a 108-5. Turning the key to Start does nothing. I have replaced the ignition switch and the solenoid with no luck. The wiring looks factory from what I can tell. I can jump the solenoid and it starts fine. I can use the pull start and it starts fine. On the voltmeter, I show 12.5v. As soon as I turn the key to Start, it drops to 0. Battery is good. But also tried booster pack just to be sure. I suspect the pto safety switch or the neutral safety on top of the transmission. The pto safety switch I'm wondering if there is a cheaper option than $50 to $70 The part is listed here: https://www.partstree.com/parts/toro-109327/ Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,519 #2 Posted 1 hour ago Where are your tester leads when it drops to zero? Or are you watching an in dash voltmeter? Share your model and serial number so we can look at the correct diagram. Share this post Link to post Share on other sites
