evanloock 269 #1 Posted 20 hours ago The stator on my Charger 12 (breakerless ignition) has given up the ghost. It is only putting out 4 volts AC. Anyone have one laying around? Part # is 237877. I am not converting to points. Engine runs fine just won't charge the battery. Thanks! Share this post Link to post Share on other sites
ri702bill 13,264 #2 Posted 19 hours ago You should place an ad in the Classified "Wanted" section.... Share this post Link to post Share on other sites
evanloock 269 #3 Posted 18 hours ago (edited) I just did. Thanks. Put it here as well in case any one of our electrical experts know why it might be putting out voltage (not totally dead) but not the 20+ AC volts per spec. Edited 18 hours ago by evanloock 1 Share this post Link to post Share on other sites
953 nut 70,021 #4 Posted 15 hours ago Check with @76c12091520h.at K&B parts. Share this post Link to post Share on other sites
Handy Don 17,625 #5 Posted 15 hours ago 2 hours ago, evanloock said: I just did. Thanks. Put it here as well in case any one of our electrical experts know why it might be putting out voltage (not totally dead) but not the 20+ AC volts per spec. If neither leg of the stator output is shorted to ground, and there is continuity at low resistance between the legs, then there is an internal short in the stator winding. Share this post Link to post Share on other sites
evanloock 269 #6 Posted 14 hours ago 1 hour ago, 953 nut said: Check with @76c12091520h.at K&B parts. Thank you I just sent him a PM. 1 Share this post Link to post Share on other sites
evanloock 269 #7 Posted 13 hours ago 1 hour ago, Handy Don said: If neither leg of the stator output is shorted to ground, and there is continuity at low resistance between the legs, then there is an internal short in the stator winding. I'll check that out and see what result I get. I have just done the AC voltage test on the 2 leads coming off the stator so far and only got 4 volts (should be 20+). I see where there are shops that refurbish discontinued stators for motorcycles and ATV's. I am going to check and see if they can redo this one. Anyone here gone this route? 1 Share this post Link to post Share on other sites
Gasaholic 397 #8 Posted 3 hours ago may want to pop your flywheel off and check the magnets in flywheel first as well.. - I have seen instances where magnets coming loose gave weird voltage readings , replacing flywheel solved the issue and the stator was just fine.... harder to find a good flywheel than to find a good stator.... 1 Share this post Link to post Share on other sites
