evanloock 266 #1 Posted 5 hours ago The stator on my Charger 12 (breakerless ignition) has given up the ghost. It is only putting out 4 volts AC. Anyone have one laying around? Part # is 237877. I am not converting to points. Engine runs fine just won't charge the battery. Thanks! Share this post Link to post Share on other sites
ri702bill 13,258 #2 Posted 4 hours ago You should place an ad in the Classified "Wanted" section.... Share this post Link to post Share on other sites
evanloock 266 #3 Posted 3 hours ago (edited) I just did. Thanks. Put it here as well in case any one of our electrical experts know why it might be putting out voltage (not totally dead) but not the 20+ AC volts per spec. Edited 3 hours ago by evanloock Share this post Link to post Share on other sites
953 nut 69,994 #4 Posted 1 hour ago Check with @76c12091520h.at K&B parts. Share this post Link to post Share on other sites
Handy Don 17,622 #5 Posted 46 minutes ago 2 hours ago, evanloock said: I just did. Thanks. Put it here as well in case any one of our electrical experts know why it might be putting out voltage (not totally dead) but not the 20+ AC volts per spec. If neither leg of the stator output is shorted to ground, and there is continuity at low resistance between the legs, then there is an internal short in the stator winding. Share this post Link to post Share on other sites
