bemslie 0 #1 Posted 4 hours ago I have a model # 79360 snow thrower - I need to replace the pulley - part # 113356. Everywhere I look, Toro parts is wanting north of $100 US. Where can I find the dimensions for this pulley? There has to be something of a somewhat generic pulley out there for considerably LESS than $100. Thanks in advance. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,512 #2 Posted 2 hours ago Will guess the shaft diameter is 7/8". Got a Princess Auto nearby? They have sheaves that bolt to a tapered hub sized to the shaft. They often are made to use both 1/2" and 5/8" wide belts so the effective diameter is different. The sheaves use an industrial way of measurement so best to measure where the correct belt rides in the groove and match up the diameter. The sheaves are secured to the hub with bolts and the same bolts are removed from their holes and entered into others to push the sheave back off .https://www.princessauto.com/en/product/single-groove-solid-cast-iron-sheaves/PA1000001359 https://www.princessauto.com/en/product/split-tapered-bushings/PA1000001199 They also have a series of stamped steel pulleys that require they be welded to a hub sized to the shaft. https://www.princessauto.com/en/product/weld-on-pulleys/PA1000001341 https://www.princessauto.com/en/product/x-series-weld-on-hubs/PA1000001386 Share this post Link to post Share on other sites
