Kid with a wheelhorse 3 #26 Posted 13 hours ago I did that and never showed any ohms Share this post Link to post Share on other sites
pfrederi 21,239 #27 Posted 12 hours ago (edited) 49 minutes ago, Kid with a wheelhorse said: I did that and never showed any ohms If by that you mean it showed open or infinity all the time then you need to clean your points again they aren't closing. When they are open you have infinity .no continuity, closed should show a very small ohm rating . One other thing run a temp ground jumper from a clean spot on the engine block to the battery neg. There is a small ground cable under your engine on those isolation mount tractors that can fail and the engine is not grounded. Jumper bypasses that potential issue. Edited 12 hours ago by pfrederi 2 1 Share this post Link to post Share on other sites
953 nut 69,863 #28 Posted 9 hours ago Do yourself a favor and cure one problem at a time, Get the ignition system working properly, get the engine running, and then you can do a functional test on the charging system. Have you done the static timing yet? Share this post Link to post Share on other sites
c-series don 12,544 #29 Posted 6 hours ago Here’s a little bit more advice: Stay here on Red Square, this is where the best and most knowledgeable Wheel Horse people are. The guys here are very smart and willing to help. They will get your tractor running. Be patient and listen to them, it will pay off. Share this post Link to post Share on other sites
