Kid with a wheelhorse
C-145 Auto electrical problems
Hi all I have recently acquired a C-145 automatic and it is in good mechanical shape but it does not have spark I have replaced the starter coil and magneto coil as well as the key switch and the solenoid and eveything is up to spec what should I do
thanks
Edited by Kid with a wheelhorse
rmaynard
When replacing the key switch, did you replace it with the correct one. There is a difference between a switch for a magneto ignition, and a battery ignition. However, you said you replace the ignition coil and the magneto coil. There can only be one or the other. A magneto system has no ignition coil and vice-versa. So lets try to figure out what you have. Do you have the ID number for the C-145? What is the year? Which engine does it have? Do you have the spec number from the engine? I'm sure we can get you going if we have the right info.
It is a 1-14259 and I replaced the switch with a 5 pin 3 position should be a 1980 model year with a k321AS and spec is 60362d
pfrederi
That spec is a battery points ignition with a 15 amp Stator for charging.  The regulator you have sitting loose is not the correct one.. The finned one mounted on the hoodstand is.  Run a jumper from Battery+ to the + terminal on the coil crank it and see if you get spark,
I have gotten power
there when I was working on it
pfrederi
If you had power on the coil and no spark next thing is points... Make sure they are opening and closing and clean them up...
squonk
C-145 has a fuse taped into the wire harness in the area between the starter and regulator. Check that for the heck of it
Fuse is fine and I cleaned the points
pfrederi
Disconnect the condenser and try
No change, would the spark plug cable cause loss of spark
gwest_ca
The tractor model number is not 1-14259
Will guess it is 01-14KE01 if the transmission filter is at the rear of the tractor
or model 01-14KS01 if the filter is on the right side of the transmission.
They changed from Sundstrand hydro's to Eaton mid-year 1980 and why the use of E and S in the model number.
It’s the second one
pfrederi
It sure could  also is the plug new.  You might want to steal a Plug wire and plug from a working tractor if you have one.
Cleaned and gapped the plug put a new wire on it to still nothing
pfrederi
if you have a test lamp hook it between the - terminal on the coil and battery positive... by hand slowly turn the engine over  the light should turn on an off as the engine is turned over.
sqrlgtr
Have you confirmed spark at points by hand and if so are you sure the points are set to open at .020 or close to it. I did have one a while back that had a bad wire going to points and was grounding everthing out. Just spit balling here.
953 nut
First things first., the ignition coil needs to be bolted to the block to make a good ground.
Send back the voltage regulator that is sitting on the battery, it is not for correct for your :wh: and has nothing to do with your lack of spark situation.
As @sqrlgtr suggested, remove the points cover and see if there is spark at the points when the engine is turned over.
The most accurate method for setting points is static timing, follow the attached vedio.
Ed Kennell
I just had a 312-8 with no spark.     Po had put in a new plug.    I checked coil, condenser, points with no change.   removed the new Chumpion plug and installed an old NKG.
Runs perfect.
1 I don’t have a test lamp but interesting idea I will look into to one
2 I have confirmed the gap on the points and it seems to be timed
3 what do you mean by ignition coil do you have a example that would help
4 volt regulator came with rectifier coil I was not going to use it
5 it is the original spark plug which I gapped and cleaned
pfrederi
If you have a multi meter we can tell you how to do it with out a test light.
Ignition coil is the can shaped thing the spark plug wire comes out of
I am not sure I know what you mean by rectifier coil.  Is it the stator that is under the flywheel it has nothing to do with spark.(see pic)
Get a new Autolite 215 or if you are in to self abuse a Champion H10
sqrlgtr
:laughing-rolling: I agree with that statement
Ed Kennell
1 hour ago, pfrederi said:
Get a new Autolight 215
Runs perfect.
953 nut
I have a miulti meter so that would be helpful and I am talking about the rectifier coil
pfrederi
Recitifer coil has nothing to do with spark and it  is called a stator
Multimeter set it to OHMs one clip on the wire from the Coil into the points one on Batt(-) As you slowly turn engine over by hand (Plug out makes it easier) you should go from infinity to a very low resistance reading.  2-4 ohm maybe
